Main > Everything Else
Most unusual item you have used in making your cab?
Stingray:
I used little plastic spacers out of an Erector Set to mount my iPac, and various other small PCBs.
-S
AlanS17:
I used angle iron for mounting the monitor (and I'll be doing it again soon).
I also a "fat" plastic threaded pin to hold the steering wheel in place. I built the railing system for it from wood and U-channeling. So I could slide the thing in place and lock it with the pin.
... and I used posterboard for a rush-job marquee. :-[
SirPoonga:
The pipe across the front for a foot rest.
Popcorrin:
Steering extension shaft out of a massey ferguson combine.
Dire Radiant:
A cheap pen cut into half inch lengths as motherboard standoffs.
