Author Topic: Illuminating Trackball  (Read 1035 times)
namedos
  • Last login:January 04, 2023, 06:18:13 pm
« on: May 04, 2005, 04:27:06 pm »
I've got my Happ's 3" trackball and I have my ultrabrite LED's and my Happs bulb holders.  Anyone have a good suggestion as to where and how to mount the LED?  I should have over an inch between my control panel and the trackball.  Thanks.
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Illuminating Trackball
« Reply #1 on: May 04, 2005, 04:46:35 pm »
Well you mount it right under the trackball center where there's a gap in the casing.  Ive heard of people using velcro to hold it in place, maybe just some strong tape/glue could hold it too.  I also saw a really good one where a flashlight reflector was used to concentrate the light to that hole only....
ahofle
    • Arcade Ambience Project
« Reply #2 on: May 04, 2005, 04:50:49 pm »
I used one of these LED cannons:
http://www.casecooler.com/labeledr.html
Using the adhesive on the LED base and some extra reinforcment tape, I mounted it right on the edge of the hole and directed the light straight up into the trackball.
« Last Edit: May 04, 2005, 05:15:41 pm by ahofle »
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: May 04, 2005, 04:57:44 pm »
I used a pcb mounting foot so the led points towards the trackball.  Lights up better this way:
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #4 on: May 04, 2005, 05:39:16 pm »
I put 3 right below the center of the hole by poking them through a piece of carboard taped to the trackball housing. Very high tech!  ;)
It lights up beautifully!
namedos
« Reply #5 on: May 04, 2005, 08:58:05 pm »
Ahofle,
They are a bulb holder that Happ's sells that goes behind the coin door.  They fit a 12v LED perfectly and have two prongs to wire it up.  They are a white plastic.  Part number is 42-0351-00.
