Author Topic: Help Needed with My First Cab  (Read 1618 times)
Freeplay
  • Last login:May 02, 2015, 06:04:19 pm
  • I'll be crosses !
« on: May 03, 2005, 05:25:53 pm »
Howdy all.
I need advice with my first cab, for a Mame setup.
I bought this cab as pictured. ( Not bad for my first buy eh..)
I already have a PC setup so, my system is ready to install.
The tricky bits:
I'm looking at a keywiz for the inputs.... straight forward, no probs
For audio output, I have a car stereo amp laying around....straight forward, no probs
But for video... I'm not sure which direction to go.
The cab came with a 33' Monitor..which I've found out to be
Pentranic - A80PNT27X - E133019 - dual resolution CRT
However there is no chassis. I've been quoted a couple of hundred dollars for a chassis.
At the moment my PC has a std VGA card.
Do I go down the TV path ( I guess I would need to get a TV Out Video Card)
and connect via RCA... fairly straight forward.
OR
Do I try to get a chassis......If I go this way, I'm not even sure how I connect an Arcade Monitor to a PC ( So I would need Help with advice in this area)
I also have no idea if the tube is OK ( I was told it was OK from the the guy I bought it off ) I've been told I can get a cheap chassis to test the tube ( around $40 )
Because there isn't a chassis in the cab at the moment, I don't even know how it connects... So if I get a test chassis how do I test it?
Of course I would like to stay with the arcade monitor if possible... but I would be in unfamiliar terrority.
I would appreciate any help... Thanks
"The Best Thing About Getting Old"
You can afford bigger and better toys
ahofle
    • Arcade Ambience Project
Re: Help Needed with My First Cab
« Reply #1 on: May 03, 2005, 05:38:38 pm »
Check out ultimarc and the ArcadeVGA card for using arcade monitors with a PC...
http://www.ultimarc.com/avgainf.html
tommy
« Reply #2 on: May 03, 2005, 06:13:31 pm »
Sweet showcase cab.
I would get a new 27"(33") arcade monitor for that baby.
Freeplay
  • I'll be crosses !
« Reply #3 on: May 03, 2005, 06:20:11 pm »
Why would you suggest that, is it not worth just getting a chassis?
tommy
« Reply #4 on: May 03, 2005, 06:26:00 pm »
Its worth just getting the chassis but, if you're not familar with the workings of the monitor(like it seems your are) you might want to go with a new monitor. The monitor might not even work with the new chassis, weather its an installer error or it didnt work to begin with.
With a new monitor everything is ready to go.
MrSaLTy
  • Last login:January 02, 2024, 12:23:54 am
  • nabisco reject
« Reply #5 on: May 03, 2005, 06:34:32 pm »
Hey I have been thinking about building a cab like that forever.... I have good plans but I am still sorta iffy on how they usually have the plexi in front mounted.  Got any closeup pics of how the monitor plexi is mounted?  Id really appreciate it. Thanks
Freeplay
  • I'll be crosses !
« Reply #6 on: May 03, 2005, 07:10:31 pm »
MrSalty
No worries...I will get a couple of shots and post them soon
The Black surround around the monitor and including the speaker wall is all one piece.
MrSaLTy
  • nabisco reject
« Reply #7 on: May 03, 2005, 11:36:40 pm »
You rock dude.   ;D
Freeplay
  • I'll be crosses !
« Reply #8 on: May 04, 2005, 03:49:01 pm »
Come on Guys  ;D
GGKoul
  • Cheesecake Apprentice
« Reply #9 on: May 04, 2005, 03:58:11 pm »
I would sell the 33" to me and get a TV for that unit.  ;D
Freeplay
  • I'll be crosses !
« Reply #10 on: May 04, 2005, 04:03:52 pm »
Thanks for your input GGKoul
What is the thought behind that...... do you consider the arcade monitor just too much hassle..... or is it just that a tv is easier?
I'm a little confused as to which dirrection to go in.  :-\
paigeoliver
  • Awesome face!
« Reply #11 on: May 05, 2005, 01:06:54 am »
Don't stick a TV in a sweet cabinet like that. A 27" arcade monitor would be a minimum.
Check out 8liners.com and check the replacement chassis they have, do the tube measuring thing they describe (you will need a multimeter), and see if their chassis will work with your tube.
Freeplay
  • I'll be crosses !
« Reply #12 on: May 05, 2005, 03:31:53 am »
Thanks Paige... I will check it out
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« Reply #13 on: May 05, 2005, 06:44:54 am »
Just curious what you plan on doing with the other 70% of the control panel?
I love the life I lead. I wish I could afford it.
Freeplay
  • I'll be crosses !
« Reply #14 on: May 05, 2005, 05:12:14 pm »
Craig I reckon the other 70% will hold empty beer cans... ;D
lil poot
  • Last login:May 03, 2009, 01:51:22 am
  • magic, magic, ninja, what!!!
« Reply #15 on: June 03, 2005, 02:17:30 pm »
your in Australia aren't you?
i think i saw that on ebay.com.au?
either way, it's harder for us down here. Have you tried Zax?
http://www.zax.com.au/amusementmachines.html
they also sell monitors. If you don't live in Oz then i guess you can disregard  ;D
Freeplay
  • I'll be crosses !
« Reply #16 on: August 20, 2005, 12:21:48 am »
Thanks Lil Poot,
I'm tryng to get a monitor out of them now.
So what setup...............mmmmmmm
