Author Topic: Player 2 button quit working on my Jamma (UPDATE)  (Read 1122 times)
BUCKETHEAD
  • Last login:April 04, 2024, 07:31:52 pm
  • Don't hate the player .... Hate the Game
« on: May 02, 2005, 08:53:18 pm »
Today i added a TMNT PCB to my JAMMA.
« Last Edit: May 03, 2005, 09:08:55 pm by BUCKETHEAD »
paigeoliver
  • Awesome face!
Re: Player 2 button quit working on my Jamma
« Reply #1 on: May 02, 2005, 09:15:52 pm »
Well the answer to this one is really obvious.
The wiring has a broken connection somewhere inbetween the microswitch and the board.
Use your multimeter (which I am betting you don't own, go buy one right now, most important tool in this hobby), to check the connection between the microswitch and the appropriate pin on the edge connector.
If you have continuity THERE, then that pin is no longer making a good connection, so get something small and bend up the part that makes contact with the PCB and see if it works then.
If you DON'T have continuity there then the connection is broken somewhere between the edge connector and the microswitch. Examine the wiring for breaks. If there is another connector inline then that is likely the problem, see if it is making good contact. If that is the problem, and you don't want to replace the whole connector, then simply splice that wire AROUND the connector.
BUCKETHEAD
« Reply #2 on: May 02, 2005, 09:59:34 pm »
No i don't have a  multi-meter.  Looks like i will be getting one.
I figured the wire is broken somewhere. Because i didn't have this problem
until i cut the harness free and moved it around. No telling how many years
it has been stuck in that position?  Like since 1988 maybe?
I guess when push comes to shove i could cut and splice it from the connector
all the way up to the button itself?  Right now it is running from the connector
to a molex connector then up to the button itself.
BUCKETHEAD
« Reply #3 on: May 03, 2005, 09:08:19 pm »
Ok here's a update.
After much trial and error, There is nothing wrong with my PLAYER 2 button.
I switched back to TURTLES IN TIME (2 - player) pcb. And set it back the way it
was when i received it.
« Last Edit: May 03, 2005, 09:17:19 pm by BUCKETHEAD »
paigeoliver
  • Awesome face!
Re: Player 2 button quit working on my Jamma (UPDATE)
« Reply #4 on: May 03, 2005, 11:04:53 pm »
Wait, are you talking about your player 2 start button, and not the action button?
If so, TMNT 4-player requires separate coin inputs for each player, and many Jamma cabs are not equipped or not wired that way. I know mine isn't.
BUCKETHEAD
« Reply #5 on: May 04, 2005, 04:42:48 am »
That might be the reason for TMNT (4-player) not letting a 2nd player in.
On my TMNT turtles in time (2-PLAYER) pcb.
« Last Edit: May 04, 2005, 04:47:09 am by BUCKETHEAD »
