Main > Main Forum
Coin door (noob question)
Pages: << < (3/3)
schleppie:
--- Quote from: CheffoJeffo on May 02, 2005, 08:54:56 pm ---
Pretty sure that it is available in 2,3 or 4 slots ...
Cheers
Oh.....didn't see that in the description.
BUCKETHEAD:
Is this what you are looking for?
His shipping is probably cheaper.
HAPP probably wants a $100.00 to ship it.
paigeoliver:
Those are the crappiest doors, or maybe it is just coincidence that every one I have ever had has been crappy.
If you want a square door I would suggest almost any other door out there over that one. I like Midway doors, stainless Williams' doors, and the old chinese square doors (used on Artic and other bootleg cabs, they are same size as midway, made better and had a nice juicy texture to them, and a huge coin return tray).
Avery:
Is this what you had in mind?
I bought, stripped, primed and repainted this (OK, not as good as the original powder coat, but that had seen better days).  I also replaced the lock, the red coin return buttons and one of the missing coin flaps.  Then I picked up a couple cabinets cheap and decided to track down the appropriate doors for those cabs.  Sigh.
This doesn't have the counter or those little magnetic coil dealies or a couple other things that nobody seems to worry about with MAME machines.  The coin mechs can tell a quarter from other coins and coin like objects.  If you'd like, I can do a continuity check on the coin switches.
Send me an e-mail and we can try to work out a deal.
Ken Layton:
Avery:
That's a Coinco door you have.
As to a two chute door, the Happ # 40-0375-00 or # 40-0055-00 should work.
Pages: << < (3/3)
Go to full version
