Main > Main Forum
Whats with all this recent 49-WAY JOYSTICK talk?
Kremmit:
--- Quote from: Buddabing on May 04, 2005, 09:06:09 am ---Unfortunately, one of them is a personal biggie. Red Baron.
I haven't seen any posts on how games with analog sticks play on the 49-way. If Red Baron plays okay, then I might take the plunge and mount a flight stick on one.
I'd check it out for you, but I never played Red Baron in the wild, and I don't have an A-Pac yet (8-axis version, Andy!) to try it with a real analog stick, so I've got nothing to compare the 49-way play to.
Tiger-Heli:
--- Quote from: Kremmit on May 05, 2005, 01:16:49 am ---
Easiest comparison would be to get a standard $15.00 PC USB joystick (more or less) and try that against the 49-ways.
Although I think the Star Wars comments were fair - You could hit the Tie Fighters if they just happened to be in your sights - slightly better than an 8-way stick, but nowhere near a true analog.
RecycledPast:
So to recap the 49 way topics, to build a pretty versatile CP I'd need about $100 USD per player?:
* Midway 49-Way Optical Joystick - $33.00
* GP-Wiz 49 Max $34.95
* Rotary Adapter $25
and 7 buttons to set the joystick modes (2,4,8, etc...)
Tiger-Heli:
--- Quote from: Recycled-Past on May 10, 2005, 02:42:05 pm ---So to recap the 49 way topics, to build a pretty versatile CP I'd need about $100 USD per player?:
If you went with the GP-Wiz49 Max - $11 or $15 per player less if you went with the Eco's.
--- Quote ---and 7 buttons to set the joystick modes (2,4,8, etc...) or has a software switching solution been built?
software switching is done, but you'll want buttons for a versatile CP anyway.
--- Quote ---Did I miss any other add-ons to the joystick? I don't think the Balltop is available yet.
Balltop should be coming soon. 1Up is doing a Tron stick version, but the rotary won't work with it.
Druin:
--- Quote from: Tiger-Heli on May 10, 2005, 02:50:02 pm ---
