Main > Everything Else
I am useless. Had enough.
Pages: << < (3/4) > >>
tommy:
I have to agree cut/try to cut your angel first and if you mess up cut that angel off and try again, dont make your final cut till the angel is right. You should have many chances to get it right till you run out of length on that panel.
danny_galaga:
plastibond is your friend (",)
Bones:
--- Quote from: DarkKobold on May 01, 2005, 01:41:38 pm ---Didn't your hands get f-'ed up in an accident BB? Isn't that why you are called Broken Bones? How is that going? I'd be surprised if you could still work with wood, after what happened to you, IIRC.
The hands are OK! I broke both wrists, destroyed a handful (pun intended) of bones in my right hand plus broke my right arm. Had enough operations to sort out most of my problems (only 1 more to go!). It took me 12 months to learn how to close and use my right hand again but all said and done, I am doing pretty bloody well.
Using power tools is
DrewKaree:
--- Quote from: BrokenBones1 on May 02, 2005, 02:45:48 am ---
The hands are OK!
It's the REST of him that's really all effed up....especially the semi-useless lump above the shoulders ;) ;D
--- Quote ---
I have been left as weak as a kitten and some pain still persists but the good news is I can still wank as fiercely as a schoolboy ogling a bra catalogue and I don
Bones:
Drew................ Ummmmm, enough said.  ::)     ;D
Last night I brought this. http://forum.arcadecontrols.com/index.php/topic,35285.msg318943.html#msg318943
I just turned it on (to check it actually worked), and it scared the bejeeezus out of me. I wonder if the store will supply me a credit because it's scary sounding?
Looking forward to giving it a whirl on the weekend and getting these cuts right.
Go to full version
