Author Topic: Picking up Pac man cab this weekend...  (Read 1384 times)
Speck
  • Last login:May 20, 2005, 11:39:49 am
« on: April 28, 2005, 03:21:31 pm »
Found a sister of a friend that has said they have a Pac Man cabinet in their basement. States that he thinks the PSU is bad. I am going to pick it up this weekend and see what is what, if I can repair it, wonderful. If it isn't repairable... would it be blasphemy to use the cab for mame and give away the parts I find? Or what?
I do NOT plan on damaging it in anyway. I love Pac Man too much :) Just need some advise.
MonitorGuru
Re: Picking up Pac man cab this weekend...
« Reply #1 on: April 28, 2005, 03:32:25 pm »
It could be a number of things...
It could be the fuses or fuse block... under $3 repair.
It could be a bad monitor ... $5 to $70 repair.
It could be a bad isolation transformer... $15 repair.
It could be a bad linear AC transformer.... $20 to $40 repair (Pac-man's can use Galaxian's ones... you need 120VAC in, and +7VAC and +14VAC output)
It could be a bad diode or capacitor or trasnistor on the pacman board to convert AC to DC.... $1 to $20 repair.
Need more info to tell for sure.
And no, dont mame it.  It *IS* the most common cabinet out there, but if the artwork is in good shape, that's worth a lot.   I'd HAPPILY trade you a pac-man that had formica on the sides and now all the artwork is destroyed (they scuffed it up to make the cement stick)....
« Last Edit: April 28, 2005, 05:06:37 pm by MonitorGuru »
Stingray
« Reply #2 on: April 28, 2005, 04:02:48 pm »
Yes it would be, and it's repairable. You just have to figure out what it needs. ;)
A real working Pac-Man is just sooooo much cooler than a MAME cab no matter how many games it can play.
-S
Speck
« Reply #3 on: April 28, 2005, 10:53:33 pm »
That's pretty much what I was thinking.
My plan of action will be: If the cab looks good and it is a fairly easy fix, I will repair it and cherish it. If the cab is in bad shape, I will be posting the parts here for the cost of shipping. Something I read somewhere about passing on good parts that you don't need, rang really true to me. So, we will see. Hopefully I will be able to pick it up this weekend.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #4 on: April 28, 2005, 10:55:51 pm »
Damnit, i knew you were a good guy..
Lilwolf
« Reply #5 on: April 29, 2005, 08:54:14 am »
btw... quick note...
you CAN mame a cabinet without destroying everything!
1) get a pacman-jamma cable (assuming you want to plug that back in.) Can be made for a few bucks... and buy one for like 20+ bucks.
2) get a jamma harness and convert the cab to jamma
3) get a jpac + arcadevga
now plug / play for all vertical 4ways.
If you plan on adding a few buttons... build a NEW control panel (keep the old one).  There was someone selling repos without art for like 15-20 bucks a bit ago.
But in the end.. you can swap back/forth between pacman and the others.
daywane
  • Last login:Yesterday at 09:30:03 pm
  • GRRRR!
« Reply #6 on: April 29, 2005, 09:26:28 am »
wow. I thought Pac man was cool to mame?
my Ms Pac and super pac are in such bad shape I fell mame is best.
Speck
« Reply #7 on: April 29, 2005, 09:57:19 am »
I DEFINATELY wasn't going to hack the old CP. :) I am waiting to setup a time for pickup, I still haven't seen it yet, but if there is anyone that needs parts to fix a PacMan, subscribe here, I will post the parts that I salvage if need be. :)
paigeoliver
  • Awesome face!
« Reply #8 on: April 29, 2005, 10:44:01 am »
I'll pay shipping on the PCB and send you back a trackball with mounting plate. I have been shopping for a Pac-board for a while. If you don't want a trackball then I can send a brand new Namco Reunion 4-way stick instead.
Pac-Man and Ms. Pac-Man are in overabundant supply, if isn't NICE with a capital N, then it isn't a big deal. 10 years from now you'll have trouble giving away Pac-Mans if they aren't mint.
« Last Edit: April 29, 2005, 10:48:09 am by paigeoliver »
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:37:55 pm
« Reply #9 on: April 29, 2005, 10:55:36 am »
maybe they just said that it has something wrong with but none really. Its completely 100% working. They just want it out of there...You Lucky boy
Free VGA Breakout Cable
tommy
« Reply #10 on: April 29, 2005, 11:25:20 am »
I also want that pacman pcb and i will trade more then paige.  ;D
Hopefully for you everything works or will work easily and you will keep it.
