Author Topic: Help the newbie...  (Read 1646 times)
loungn14
  • Last login:November 28, 2006, 11:19:56 am
Help the newbie...
« on: April 26, 2005, 10:21:54 am »
Sorry for the boring post...but have searched everywhere for the answer...and have to ask..
First I would love to say that this forum is awesome.  I have been lurking for quite some time and the wealth of knowledge is incredible...
But...
I recently purchased a imperial trackball for the cab I am building..
Stupid question is ....  What direction is it mounted in?  I have noticed that it tends to spin to the left side after a second if positioned with the bottom and right roller.  If positioned with both bottom rollers at 45 degree angles and the third horizontal it seems to be fine... ( will be using with the optipac)
Sorry for the ignorance...been searching for days and can't seem to find the answer...
Thanks in advance...
Vicious
Re: Help the newbie...
« Reply #1 on: April 26, 2005, 12:12:58 pm »
Well, let me be the first to welcome you (and attempt a little help).
Now I've only had a Happ trackball, but it was easy to figure out which way was up because of the mounting plate.  If you are using a mounting plate it should be easy to do, and judging from this auction, a Happ one should work with your Betson (check the pics at the bottom).  Hope this helps a little.
tommy
« Reply #2 on: April 26, 2005, 12:20:22 pm »
I love how most of the new 1st post newbs always say they have been "lurking"  :laugh:   Welcome.
KenToad
  • Last login:May 05, 2024, 08:22:38 am
  • Flap Flap Flap
« Reply #3 on: April 26, 2005, 12:30:23 pm »
Yeah, how many newbies can you make out back there in the shadows ... creepy ... if I hadn't already been there.  Welcome, as well, and hope you figured out how to mount that trackball.  I can't help as I've never owned one.
KenToad
markrvp
  • NFL Expert
« Reply #4 on: April 26, 2005, 12:39:44 pm »
Welcome to the board.
loungn14
« Reply #5 on: April 26, 2005, 12:51:32 pm »
THANK YOU!!!!!!!!! THATS EXACTLY WHAT I NEEDED!!!!!!!!!!!!
The amount of help on this forum never stop amazing me...
btw...too funny about the lurking thing...never though about it like that...just never bothered to post as couldn't supply my experience to others......yet!
Stingray
« Reply #6 on: April 26, 2005, 01:00:10 pm »
Does it reall matter in a MAME cab? I mean yes it matters if you're plugging it into an existing harness, but if you're connecting it to a hacked mouse or an Optipac, you could just as easily connect left & right to up & down & vice-versa. It would still work if mounted in the correct orientation.
Although I'm sure it's better to mount it correctly.
-S
markrvp
  • NFL Expert
« Reply #7 on: April 26, 2005, 01:05:51 pm »
You can change it to whatever you want in MAME, but if you are also using it as a mouse in Windows  it is best to keep it in the proper orientation.
Here is what the inside looks like.
« Last Edit: April 26, 2005, 01:07:44 pm by markrvp »
Stingray
« Reply #8 on: April 26, 2005, 01:08:58 pm »
You can change it to whatever you want in MAME, but for Windows functionality it is best to keep it in the proper orientation.
If you connected up & down to left and right on the hacked mouse/ Optipac & vice versa, it would work correctly in Windows as well as in MAME, you wouldn't have to change any settings.
-S
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #9 on: April 26, 2005, 01:22:43 pm »
.. by the way loungn14
what method are you using to mount this thing?
markrvp
  • NFL Expert
« Reply #10 on: April 26, 2005, 02:54:10 pm »
-S
You are correct.
« Last Edit: April 26, 2005, 03:11:25 pm by markrvp »
Stingray
« Reply #11 on: April 26, 2005, 03:36:23 pm »
Understood. ;D
-S
Witchboard
« Reply #12 on: April 26, 2005, 03:53:39 pm »
When I saw the topic of this thread... for some reason, I expected a link to a flash game.  ;D
IntruderAlert
    • Intruder Alert
« Reply #13 on: April 26, 2005, 04:39:10 pm »
It IS a game see..
it's just not a really fun one
