Main > Everything Else
need a name for my PC tech support business
Hoagie_one:
Electro-Man : Adventures in Computer Geekdom
SOAPboy:
--- Quote from: hulkster on April 25, 2005, 10:16:28 am ---well seeing as this is for work type stuff, it needs to be somewhat professional.
GGKoul:
Just a couple of things.. are you doing this on the side of your normal job for friends or are you looking to this full time? Are you just providing tech support/fixing windows and driver issues or are you going to be reselling items to the enduser?
The reason I ask is I used to do this on the side via my own company with a vendors permit. But I had to stop, as I had NO time to handle the after service support calls. As I was a one man shop doing this on the side for friends, but when I started doing a couple of friends friends, people I rarely knew. Then I ran into trouble, because I would do the service and fix or install whatever and leave. But then I would be getting calls about this not working and that not working... That's when the fun began. As I would work 9-5 then drive 1 hour home just to work servicing stupid issues for 3/4 hours a night for $25/hr. And it started to become not worth my time to do this. So I stopped.
If I were you, I would do this personally and have them pay you cash. Only if you do work for a business that requires a receipt would I worry about a business name. As once you collect the revenue, you SHOULD claim the amount on your taxes.
DrewKaree:
You're in Kentucky.....the perfect name has been sitting in front of you all this time!
High Tech Rednex LTD
daywane:
--- Quote from: DrewKaree on April 25, 2005, 09:39:01 pm ---You're in Kentucky.....the perfect name has been sitting in front of you all this time!
Hay cool your in KY.
trade you a chicken to fix my Pacard bell ;D
