Main > Everything Else
VOB to Mpeg or other friendly format
Pages: << < (2/2)
CheffoJeffo:
I am able to rename VOB files in XP ... I suspect that your shell settings may be what is preventing you from doing this successfully (you should get a warning if you try to change the extension).
VOB files are a subset of MPEG-2, so renaming usually works. Sometimes, though, depending on the software being used, you can end up losing aspect/ratio or audio.
Best bet is a good DVD ripper/encoder.
A good place to start is:
http://www.videohelp.com/guides.php
Pull down the Format Conversion menu and you are off to the races.
Cheers.
DrewKaree:
Doesn't Nero do this as well, with some plug-in or something?
Pages: << < (2/2)
Go to full version
