Author Topic: Accuracy Control Response  (Read 672 times)
Searcher7
  • Last login:June 21, 2009, 10:45:22 pm
« on: April 23, 2005, 03:03:48 pm »
Can anyone confirm whether or not it is possible to get the exact control response in MAME(for games like Star Trek, Millipede, Star Wars, ect.) as you get in the original arcade games.
I assume that this comes down to the degree that one can set the sensitivity of the settings, and I wanted to be sure that if I used the control panels taken off the original arcade games, I wouldn't be able to tell the difference.
Thanks a lot.
Darren
paigeoliver
  • Awesome face!
Re: Accuracy Control Response
« Reply #1 on: April 23, 2005, 03:46:05 pm »
You have to tune the settings, but you can get it exact. The problem is that it is almost impossible to correctly tune the settings without having a real machine next to the Mame cabinet.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: April 23, 2005, 06:20:28 pm »
And that is true in most cases.  There is another recent thread about Robotron playing faster in MAME than in the real hardware, and I'm not sure of a way to slow it down.
SirPeale
  • Green Mountain Man
« Reply #3 on: April 23, 2005, 06:44:02 pm »
Aaron Giles rewrote the Williams driver for .95u4, and he's addressing the speed issue.  Not sure how accurate it is now.
paigeoliver
  • Awesome face!
« Reply #4 on: April 23, 2005, 11:38:01 pm »
That is a different issue, Robotron itself might not be slowing down correctly, but the controls are sure responding properly. Anyway, the poster was talking about analog games.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #5 on: April 24, 2005, 12:23:10 am »
My buddy and I were playing Double Dragon on his cab the other day, and it chugged. Apparently the original did the same thing (I didn't remember that) and you can fix it by using a cheat file, which seemed like a ridiculous way to fix it, personally.
Searcher7
« Reply #6 on: April 24, 2005, 10:10:14 am »
Getting back to the accuracy of control response. I guess my main concern is how sensitive the adjustments are in MAME.
I was thinking that I'd experiment with how far the shooter would go in Millipede if I were turn the trackball one revolution(360 degrees). But the speed one spins the trackball may also be a factor.
I would do something simular on my Star Trek arcade game.
Then try to duplicate the same in the respective MAME games.
Star Wars would be difficult.
Thanks.
Darren
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
« Reply #7 on: April 24, 2005, 01:33:04 pm »
There's some measurements in this thread.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #8 on: April 24, 2005, 03:16:16 pm »
Play the bootleg ones.. they dont chug... O_o
