Author Topic: Best way to Diffuse light on an led?  (Read 3403 times)
AmericanDemon
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
« on: April 22, 2005, 02:00:02 pm »
I am trying to find a simple way to diffuse light on an LED.  It will probably be a superbright led.  Not sure of sizing yet.  But I was curious as to what everyone else has tried....
Re: Best way to Diffuse light on an led?
« Reply #1 on: April 22, 2005, 02:49:42 pm »
Do you want to diffuse it or just dim it?  If you want to dim it, give it less voltage.
Witchboard
« Reply #2 on: April 22, 2005, 03:07:31 pm »
I'm going to have to diffuse a couple of LEDs on a project of mine and thought of sandblasting/sanding one side of a piece of plexi and put over it.  The pieces I'm looking at will probably be around a nickle to quarter size.
RandyT
  • Last login:May 06, 2024, 12:12:44 pm
    • GroovyGameGear.com
« Reply #3 on: April 22, 2005, 03:24:22 pm »
Paint them with superglue and then sprinkle them with glass sandblast beads?
I haven't tried it, but it sounds like it should work :)
RandyT
Dire Radiant
  • Last login:March 25, 2011, 03:11:36 am
  • Cor, chief!
« Reply #4 on: April 22, 2005, 06:17:41 pm »
Sand the outside with 400 grit sandpaper. You can make it light more evenly by sanding the rounded end flat. A lot of PC case modders have used this technique to good effect.
rdagger
« Reply #5 on: April 22, 2005, 06:31:57 pm »
You can just buy diffused LED's.
AmericanDemon
« Reply #6 on: April 23, 2005, 12:38:16 am »
I tried looking for diffused ones... but alas, I could only find red ones.  I will try the sanding of them and see how it works out.
Thanks for the suggestions.  I'll try them one at a time.
rdagger
« Reply #7 on: April 23, 2005, 03:45:09 am »
