Main > Main Forum
Need Information on this cab!
APFelon:
Are you looking to set up a "plunger - like" switch, Stingray?
It might be pretty simple to hack one together. A regular plunger and spring assembly with a way to trigger an opto switch with a modded actuator on the plunger itself, with a rubber bumper stop of sorts to simulate hitting the "ball"... It might not be that hard to hack one together.
APf
Stingray:
--- Quote from: APFelon on May 11, 2005, 07:22:55 am ---Are you looking to set up a "plunger - like" switch, Stingray?
APf
Yeah, that's true. I hadn't thought of trying to hack a real one. Now I just need to find one to experiment with.
-S
AlanS17:
Wow... we must all have ADD. How off-topic can we get? :)
(I know I've got ADD.)
youki:
I finally find time to take some measurements.
I considered the cabinet as big rectangular boxes but it is not true. So it is just to give you an idea.
RayB:
Thank Youki!
:D
