Author Topic: db25 solder or crimp?  (Read 949 times)
kenzo42
  • Last login:March 07, 2023, 09:50:13 pm
« on: April 21, 2005, 02:49:23 am »
which is preferred for strength/stability? solder or crimp?
is that insert/removal tool worth getting?
what do you use to house the *length* of the 25 wires? (and i don't mean the D-sub hood)
thanks fellas.
dabone
  • Last login:October 31, 2023, 12:03:37 pm
  • Time to work...
Re: db25 solder or crimp?
« Reply #1 on: April 21, 2005, 07:52:54 am »
Crimp then solder!   ;D
Actually, solder is ALOT stronger in the long run and will also keep corrosion from forming in the joint unlike crimping.
Later,
dabone
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #2 on: April 21, 2005, 08:00:01 am »
  Solder is definitely the best for strength and stability obviously, but it's a huge pain in the butt if you need to unwire your CP for something.  If anything, make sure you solder them to quick disconnects and not the microswitches! :)
  Huh?
http://cableorganizer.com/spiral-wrap/index.html
thanks fellas.
 I'm not a fella, but you're welcome.
-sab
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: April 21, 2005, 10:30:43 am »
Probably.
Actually, the method I would recommend is buying the appropriate length full through RS-232 M/F cable (you can get them for like $6-10 on www.pricewatch.com, click on cables and search for RS232).  Cut the cable in the middle and run one end to the CP and one end to the encoder.  No need to crimp or solder if you do this, and often it's cheaper than buying the connectors separately.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #4 on: April 21, 2005, 11:11:52 am »
shrink wrap
nomad
  • Last login:March 31, 2007, 04:15:28 pm
« Reply #5 on: April 21, 2005, 03:32:18 pm »
Probably.
I did something similar to that and it works like a charm.
kenzo42
« Reply #6 on: April 21, 2005, 03:43:17 pm »
i noticed that when i cut my db25 printer cable in half, there were only ~9 wires in it. i guess on one end, they are either shared or not used.
are there db25's that actually have all 25 wires to each pin?
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: April 21, 2005, 03:48:58 pm »
Yep - you want an RS-232 cable, not a printer cable and not a null modem cable.  Not a bad idea to ask the company you buy it from if it is fully populated (if they know!).
nomad
« Reply #8 on: April 21, 2005, 10:03:26 pm »
Radioshack sells db25 cables with all 25 wires.
kenzo42
« Reply #9 on: April 22, 2005, 01:08:20 am »
could you post a part # for that radio shack fully populated db25? thanks.
