Author Topic: correct way to ground this  (Read 729 times)
kenzo42
  • Last login:March 07, 2023, 09:50:13 pm
« on: April 16, 2005, 04:54:51 am »
hey everyone,
i have a jamma cab and it only has 2 prongs. the back of the cab has a ground screw. however, i am using a 2 prong step down converter that has 3 prong outputs.
is the step down converter not really grounded since its power plug is only 2 prong? what are my options?
thanks
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: correct way to ground this
« Reply #1 on: April 16, 2005, 10:05:39 am »
Take a look at this diagram I threw together in the Arcade Misc forum, it's not exactly your setup, but has some relevance.
As far as I can tell, you should run a heavy wire from the ground prong on your new plug to your monitor, metal control panel and the inside of the coin door.
kenzo42
« Reply #2 on: April 16, 2005, 12:35:23 pm »
what if my step down converter, which my cab is plugged into,  doesn't have an earth ground though? will my cab still be grounded if i do it your method?
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #3 on: April 16, 2005, 01:17:45 pm »
I dont quite get it, but theres two types of "ground".  Theres the negative current, called a ground, and theres an earth ground.  On a two prong plug, you get + and -.  So the screw at the back of your cabinet should lead to an earth ground.  I dont know about transformers, but anything that is plugged in with two prongs is not earth-grounded.
I just got it.  The step down converter is probably not earth grounded, since it only uses 2 prongs.  You probably have to put a ground wire to it.
« Last Edit: April 16, 2005, 01:19:23 pm by cholin »
flyguy1821
  • Last login:October 23, 2022, 11:06:19 pm
« Reply #4 on: April 17, 2005, 10:40:50 pm »
I am confused.  How many prongs are on your transformer?
kenzo42
« Reply #5 on: April 18, 2005, 01:32:39 am »
my transformer power plug has 2 prongs.
the transformer outputs 100v via 3 prongs.
my cab has 2 prongs w/ an earth ground screw from the back of the cab.
my question is how can i ground my cab correctly, b/c last time i blew a fuse on the transformer.
would it be possible to add an earth ground onto the transformer, and then running the earth ground plug from the back of the cab into the transformer earth ground outlet?
thanks.
