Author Topic: LS-30's  (Read 4130 times)
samusaran
  • Last login:March 16, 2012, 07:58:00 pm
  • Let the games begin!
LS-30's
« on: April 14, 2005, 06:16:14 pm »
hi,ive just bought 2 of these joysticks really cheap but they dont come with the 13 pin harness which connects to druins interface.could i make my own harness to get them to work.or is there any other way to connect them apart from druins interface,thanks.
Tiger-Heli
    • Tiger-Heli
Re: LS-30's
« Reply #1 on: April 15, 2005, 09:14:37 am »
You can make your own - or I think the harness that Happ sells for the mechanical rotary joystick (that Happ sells separately) will work, but I'm not certain of this.
If you have an encoder with enough inputs (16 per stick plus buttons), you can wire them directly to the encoder and use MAME analog Plus, and bypass Druin's board (might be a very interesting use for a GP-Wiz32, now that I think about it), but I think Ikari doesn't work for some reason (the other games are fine though).
rdagger
Re: LS-30's
« Reply #2 on: April 15, 2005, 11:37:59 am »
The LS-30 are not the most reliable joystick.
Hoagie_one
  • Um....whats a cabinet
Re: LS-30's
« Reply #3 on: April 15, 2005, 12:25:55 pm »
From Druin's site
samusaran
Re: LS-30's
« Reply #4 on: April 15, 2005, 02:14:20 pm »
thx for info guys,cheers
samusaran
Re: LS-30's
« Reply #5 on: April 15, 2005, 06:22:28 pm »
ive been looking at mame analogue + and it seems you have to compile it(whatever that means).well over my head.if i got an ipac and noname mame32 would that work.
Hoagie_one
Re: LS-30's
« Reply #6 on: April 15, 2005, 07:17:15 pm »
Id recomend the druin interface...its a little more money to spend but  it will make things easier in the end
Tiger-Heli
    • Tiger-Heli
Re: LS-30's
« Reply #7 on: April 16, 2005, 06:17:46 am »
Not true, there are (were?) binaries available.  As far as I know there isn't a recent one, check the features pages on Mame Analog +TM (or maybe Popular generic Emu Analog +)  :police: for the version that added direct LS-30 support and use that.
NoNameMAME32TM or NoNamePopularGenenricEmu32 -  Most versions included the comparable Analog Plus code, but . . . Often Analog Plus was not updated b/c it didn't work with the latest Mame version.  In this case the code was left out of NoName.  So you have two things to check here-is the build recent enough to include the rotary code, and is Analog Plus added to this build.
samusaran
Re: LS-30's
« Reply #8 on: April 16, 2005, 04:01:01 pm »
ive got noname mame32 0.83.14.in the controller options it says its got support for rotary 12 direction and rotary official dial.is this the one?
Tiger-Heli
    • Tiger-Heli
Re: LS-30's
« Reply #9 on: April 16, 2005, 04:37:57 pm »
Yes, that should work.  See the Mame Analog Plus site for help in setting it up.
samusaran
Re: LS-30's
« Reply #10 on: April 17, 2005, 04:04:04 am »
From Druin's site
so if i went this way would pin 1 on the joystick go to pin 13 on druins interface.pin 2 on joystick go to pin 12 on druins interface and so on.
Hoagie_one
Re: LS-30's
« Reply #11 on: April 17, 2005, 09:29:27 am »
yup
samusaran
Re: LS-30's
« Reply #12 on: May 01, 2005, 03:57:20 am »
ive now got my druins interface but im still a bit confused as to making my own harness.if i had joystick on left hand side and druins on right hand side facing each other,would the wiring go straight over to the corresponding one or would each wire cross over each other.
samusaran
Re: LS-30's
« Reply #13 on: May 03, 2005, 04:08:08 am »
ive figured it.finally made my own harness.works great too.
Hoagie_one
Re: LS-30's
« Reply #14 on: May 03, 2005, 07:43:14 am »
got pics?
samusaran
Re: LS-30's
« Reply #15 on: May 03, 2005, 09:01:37 am »
try and take some later.its not a pretty sight but hey it works.i took 1 end of hdd cable and split it to leave the 13 wires needed.i tried it on joystick side but it was a bit tight so i used this plastic plug i found which fitted perfect.then joined them in middle.
samusaran
Re: LS-30's
« Reply #16 on: May 03, 2005, 09:55:05 am »
here we go
Hoagie_one
Re: LS-30's
« Reply #17 on: May 03, 2005, 11:18:24 am »
quite a hack job, good going
samusaran
Re: LS-30's
« Reply #18 on: May 03, 2005, 01:44:05 pm »
now i know it works i'll tidy it up a bit.
Druin
  • Last login:May 10, 2009, 02:30:37 am
Re: LS-30's
« Reply #19 on: May 03, 2005, 06:33:52 pm »
WHAT DID YOU DO TO MY INTERFACE??
Hahahah nice cable.  I've been wondering if I can find a compatible connector (the proper pin size) that would make an easy to build harness.  Then I could at least provide part numbers and possible sources for anyone needing them for times like this.
The original connector I think was JST and I looked through the catalogs once and didn't see anything (didn't look too hard).  But I think Amp might make something that fits.
I'm doing something at work that involves a 3 pin connector that looks mighty similar to these pins so when I get samples in I'm going to see how they mate to the LS30 pins.
s4tay
  • Last login:February 02, 2013, 10:53:24 am
  • Be quiet, Brain, or I'll stab you with a Q-tip
Re: LS-30's
« Reply #20 on: May 03, 2005, 07:37:05 pm »
The actual JST connectors and pins are:
Cable Connector: H13P-SHF-AA
Connector Pins: SHF-001T-0.8BS
PCB Connector RT Angle: BS13-SHF-1AA
I ordered a few and they are the exact connectors/pins that comes with the LS-30.
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: LS-30's
« Reply #21 on: May 04, 2005, 12:09:36 am »
Bob Roberts sells connectors that'll work.  You just have to know which size pins you have, and how many per inch.  Dunno if they're cheaper than from JST, but you know you're dealing with a good guy when you order from Bob.
