Author Topic: Arcade Bones (Marquee & Dashboard graphics finalised)  (Read 211814 times)
Bones
  • [Moderator]
Re: Arcade Bones (18/9/05 Priming begins)
« Reply #440 on: September 18, 2005, 03:55:33 am »
Hungover today. Update will be short.
Finished sanding and cleaned up surfaces with a rag and turps. Applied two coats of MDF sealer to visible areas with a paintbrush. Results are average. I will buy some rollers mid week for future coats.
I will try and finish sealing remaining areas of cabinet this week in preparation of more fine sanding and further undercoating next weekend.
Bones
  • [Moderator]
« Reply #441 on: September 18, 2005, 06:54:29 am »
its really starting to come together!
Yes, my journey up this steep hill is almost complete, I am anticipating the downhill rush that will build to a climax sometime before November.
that white knight mdf primer is the bees knees! use a really fine foam roller...
Fine knee foam bee roller, gotcha. Thanks mate I will check Bunnings.
cdbrown
  • Last login:October 16, 2017, 09:52:03 pm
  • Bowowow
« Reply #442 on: September 18, 2005, 10:59:17 pm »
I brushed 2 coats of that same primer - was quite thick stuff and now I have very visible brush strokes.  I wish I had have used a roller, now I hve a lot of sanding to do to bring it back to a nice surface before top coating.  Make sure to get foam brushes as well to do the edges.
http://www.camartech.com.au/ress/shop.php3?aisle=painting-brushes#
Bones
  • [Moderator]
« Reply #443 on: September 18, 2005, 11:10:52 pm »
I put the first coat on really thin and it remained quite see-through in many areas. The second coat went on smoother and a lot quicker and the wood surface became more hidden.
But yeah, my crappy painting skills and the $30.00 paintbrush I brought that dropped hairs everywhere have ensured I have a lot of finishing work to do....
I will continue doing what I have done with the paintbrush but after the initial base has been put on and cut back nice and smooth, I will definitely use rollers from that moment forward.
tommy
« Reply #444 on: September 19, 2005, 12:46:23 pm »
I think you should start over, i don't care for how it's looking.  ;D
Re: Arcade Bones (Update of no significance)
« Reply #445 on: September 19, 2005, 12:51:59 pm »
I just have one question Bones.....Is the weather always so damn nice there?
Bones
  • [Moderator]
« Reply #446 on: September 19, 2005, 04:17:20 pm »
Chads right. I don't even really exist.
Bones
  • [Moderator]
Re: Arcade Bones (24/9/05 Priming continues)
« Reply #447 on: September 24, 2005, 01:35:40 am »
Again, nothing much to report this Saturday.
I sanded down the sides previously primed with a paint brush and applied a third coat of primer with a fine foam roller. (Thanks danny)
Results are better. Priming and sanding will continue for another week or three.
My little assistant helped with the insides.
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #448 on: September 24, 2005, 06:19:44 am »
I guess I'll be the first..........
AAAAAAawwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
Signature tags are dumb.
Boz
  • Last login:March 23, 2025, 03:55:29 pm
    • Battle Chasers Upright Cabinet
« Reply #449 on: September 24, 2005, 07:57:16 am »
I'm so excited to see the finished product, I can't stand it! Vicarious living is one of the century's greatest inventions. :) I know you've been working on it for many months now, but aren't you going apes**t not being able to play it yet?
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #450 on: September 24, 2005, 08:28:40 am »
the child seems a bit happy for painting  :-X
Slow In Fast Out
Bones
  • [Moderator]
« Reply #451 on: September 24, 2005, 09:14:11 am »
Yeah, you would think that but the answer is no.
It's not that I don't want to play it because I do, but it's more like- "OK, this has gone on long enough".
Right now I just want it finished. I am yearning for free weekends.  I have been motivated enough to work every weekend since I begun but it's starting to wear off a little so close to the finish line.
paigeoliver
  • Awesome face!
« Reply #452 on: September 24, 2005, 09:40:37 am »
Bones, can you possibly take another picture of your assistant working on the cabinet, specifically one that makes it absolutely clear that it IS an arcade cabinet. It could be useful to me in persuading future wives.
Bones
  • [Moderator]
« Reply #453 on: September 24, 2005, 07:19:50 pm »
To do what? Paint cabinets for you?
paigeoliver
  • Awesome face!
« Reply #454 on: September 25, 2005, 10:36:04 pm »
No, to let me build games in the living room!! ;D ;D
Bones
  • [Moderator]
« Reply #455 on: September 25, 2005, 11:07:06 pm »
I am pretty sure I can't help you there. Even I don't try and push my luck that far.....
Boz
« Reply #456 on: September 30, 2005, 02:55:36 am »
I've read through this thread more times over the last 2 weeks than I care to admit. But... Mr Bones, I have a couple of mix-n-match, oddball questions for you.
1. Would you mind posting a couple of additional pics of the back of your control panel (the part that seats against the cabinet) I'm having a hard time seeing how you've planned to secure it to the cabinet so that it won't move at all.
2. What influenced your decision to use those ball top joysticks as opposed to the "competition" variety? Authentic feel? Price?
3. Comment: looks like your rocker switches (your admin switches) are upside-down unless it's the rule of thumb in Aussie that "toward the equator" is off.  ;)
I have to say, however, that your design and the hard work you have put in to this project has inspired me more than many others because you aren't a veteran woodworker (had to buy your first sets of tools), had never built a cabinet before, and don't strike me as a geek (TBD :))
EDIT: provide link to control panel pic I'm talking about above
EDIT 2: Ok... nevermind on question 1. I thought you were actually going to use those case latches. (my bad)
« Last Edit: September 30, 2005, 03:35:39 am by In2ishun »
Bones
  • [Moderator]
« Reply #457 on: September 30, 2005, 04:36:51 am »
Sorry man, I am unable to supply more pics at this stage as everything is back in pieces again but I will post something at a later stage during final assembly.
I think you may be struggling with the angle of this photo. The white painted section is the CP box (coffin  ::)) and the CP fits into this and is held down by gravity only. The CP has legs around 2" deep that locate it and stop it going anywhere. The coffin itself is bolted down and cannot move. (The case latches hold the dashboard in place only)
Nothing in this project has been based around a budget (except paying freakin $100 in freight for a freakin bezel) and I did not get a chance to try the joysticks out before I purchased. Here in Oz there are limited suppliers of arcade parts so I pretty much ordered what was available at the height of my excitement.
There is another place selling some Happ's joysticks now but I like to do my shopping all at the one place and this was what Ozstick had available at the time. I had a goal when I started to make this cab from locally available parts, in reality I now wish I hadn't. I had some bizare idea about supporting the developing hobby in my country...blah blah blah.
Are they really? Ohh well, live and learn. Thank you for highlighting my stupidity.
In reality all I really purchased was a circular saw, jigsaw and dropsaw. But you are right, my woodworking skills are very amateur and nah, I am more of a dork than a geek.
Thanks for all the nice comments and glad you have found the thread useful and perhaps my journey even a little humorous, after I finish all this horrid painting there will be more interesting updates on the way.
Cheers,
Bones 8)
« Reply #458 on: September 30, 2005, 10:57:06 am »
Nice on having the daughter help you.  My older son and I have tons of quality time working on games.  My younger son doesn't care to do it yet, it's still over his head.  He just wants them on and playable.
Bones
  • [Moderator]
« Reply #459 on: September 30, 2005, 09:21:09 pm »
Yeah it has been cool getting her involved and she enjoyed the painting but man, she has left me with some rough work to fix up. Who would have thought a 4 year old would do such an average job....   8)
Bones
  • [Moderator]
Re: Arcade Bones (1/10/05 Priming & painting)
« Reply #460 on: October 01, 2005, 12:14:54 am »
Saturday update
Have now put three very thin coats of sealer on the sides which were sanded at 240 grit between coats and the insides were also sealed with a single coat thicker coat.
Also started painting flat-black where this needs to go. Touch up will be with a paintbrush and I will then apply another full coating using the roller. When all the black is done to final finish, I will sand the sides and apply a final coat of sealer in preparation for undercoat & colour.
Waiting for paint to dry is a waste of time.
Boz
« Reply #461 on: October 01, 2005, 11:01:24 pm »
As I was planning out my own control panel today on paper, I wanted to know just how big the coffin top actually was. From the measurements on page 5 (I believe), I used Photoshop to resize the last big copy of it you posted, to the full 47 x 22. I used Illustrator to print it out on as many sheets of paper as it would take and taped them all together to get a real-world idea of the size.
DUDE! That thing could sink the titanic! Very nice!  ;D
At any rate, my under-design CP will likely be slightly smaller, but not by much since four person gaming is the fun I hope to have.
Bones
  • [Moderator]
« Reply #462 on: October 02, 2005, 08:17:28 pm »
Yeah.... It is big. This pic shows the proportions well. I just couldn't bring myself to build a squashy 4 player CP.
When the colour goes on it will be interesting to see what effect colour has on the appearance and size.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #463 on: October 02, 2005, 08:56:52 pm »
That CP does conjure images of a coffin when it's open like that   ;)
That is going to be a kick-ass cab for sure.
Bones
  • [Moderator]
« Reply #464 on: October 03, 2005, 12:10:21 am »
Well hopefully, if it's ever finished. The only thing I hate more than painting is sanding before I paint....   ::)
Progress has definitely slowed.
tommy
« Reply #465 on: October 03, 2005, 12:22:31 pm »
I was just looking at your drink holders... do you have any extra wood protection from all the condensation that's going to come of those drinks?
Hate to see you start to put everything in the cab and have problems.
Aloha.  ;)
Boz
« Reply #466 on: October 03, 2005, 05:02:28 pm »
I believe those are actually speaker holes. The one's just above the control panel, right?
Or was that a joke -- intended on suckering in the noob who responds and lining him up for unending ridicule. ~sigh~
:D
Bones
  • [Moderator]
« Reply #467 on: October 03, 2005, 05:18:39 pm »
In2ishun is right. The holes are for speakers.
Anybody who brings a drink near my finished cab will be beaten with great vengeance and furious anger.
Freeplay
  • Last login:May 02, 2015, 06:04:19 pm
  • I'll be crosses !
« Reply #468 on: October 04, 2005, 03:31:38 am »
Bones... I'm with you, sanding and painting suck.
Why hasn't anyone tried building with pre laminated mdf ( Kitchen Cupboard Stuff? )
"The Best Thing About Getting Old"
You can afford bigger and better toys
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #469 on: October 06, 2005, 09:34:53 pm »
Because unless you use the right tools, the stuff tends to chip on the edges quite easily.  Even if you DO use the right tools, it still can happen.
Laminating after cutting your parts out requires the right tools as well, but you're not locked in to the colors they have in stock, although there's a better than average chance that NO ONE needs any color other than the stock stuff, so that might be a wash.
Price is also another consideration, although your area may be different than mine.  A sheet of MDO (that's what they call the stuff I believe you to be talking about) is $10 more per sheet by me, and it's also heavier than even a sheet of standard heavy-ass MDF
Bones
  • [Moderator]
Re: Arcade Bones (10/10/05 Painting woes.)
« Reply #470 on: October 09, 2005, 07:13:21 pm »
It has been sometime since my last significant update and although I have been working constantly on my cab, I really don
Bones
  • [Moderator]
Re: Arcade Bones (A splash of colour! Update 16/10/05)
« Reply #471 on: October 15, 2005, 08:30:20 pm »
Yesterday I applied two coats of undercoat over the top of my previously sanded and primed white surface. The undercoat is basically white with a black tint added to produce a grey finish. This was necessary in order to obtain the final colour I have chosen for my cab.
It was later explained to me that the original MDF sealer I used could have had the black tint added which would have reduced much of the previous work and help keep cost down.
At first I was a little pissed about not realising this but considering the problems I had along the way with the putty expanding, the amount of work and paint used would not have changed anyway.
The cab photo pretty much looks white not grey so I have included my paint stirrer which is in fact white and the difference can easily be seen.
Bones
  • [Moderator]
« Reply #472 on: October 15, 2005, 08:30:57 pm »
My colour of choice is called Jack-O-Lantern and is identified by the Wattyl colour code 19A-1A. It is not orange like a piece of fruit but has a more
Elfman
  • Last login:February 01, 2012, 05:58:11 pm
  • Cabinet done! CP Done! Just tweaks left to do.
    • My Corner of the World
« Reply #473 on: October 15, 2005, 08:47:39 pm »
Damn, that almost looks Photoshoped.
Looks good though!
Bones
  • [Moderator]
« Reply #474 on: October 15, 2005, 08:51:13 pm »
I suppose I will take that as a compliment!
I have worked incredibly hard in the painting department and invested much more time than I thought it would initially require so I am optimistic for good results....
tommy
« Reply #475 on: October 16, 2005, 03:40:21 am »
NO. you're not going orange are you? Grey or blue would be good.
M3talhead
« Reply #476 on: October 16, 2005, 04:00:02 am »
Damnit 'Bones, why didnt you consult us first before painting the sides!! Its our project too ya know! :police:
Bones
  • [Moderator]
« Reply #477 on: October 16, 2005, 04:56:09 am »
Ahem... Gentlemen, you have had many months to submit your objections if any.
Cabinet will be Orange, T-Molding is black which is the only colour I could get locally.
Yeah, it's orange but in the flesh I am liking it. Sideart with a white border and black t-molding will bring out its potential.
Can't wait for the objections when I paint the front white.  And the crowd goes wild.
« Last Edit: October 16, 2005, 04:59:25 am by BrokenBones »
DrewKaree
  • HAH! Nice one!
« Reply #478 on: October 16, 2005, 11:24:24 am »
Hey, everyone seems to like a good DK Jr resto, and look at that putrid color!  Besides, if it's too hideous and Mrs Bones won't let it in the house, he'll be re-painting it toot-sweet or sending her to stay with me, so either way, we all win. ;D
Bones
  • [Moderator]
« Reply #479 on: October 17, 2005, 02:40:37 am »
You are actually not far off the mark with that comment....
The colour was inspired by some of the hideous (yet common) colours of the later 70's and early 80's. My hope is the finished product will have a retro feel.
Under the glow of my garage lights it has taken on a filthy mustard type appearance. With the suns rays the orange becomes more intensified and convincing. I may have accidentally created a hippy mood-cabinet.
I chose mustard over the other colour description that I could have used which is of course "baby ---Cleavland steamer---".
