Main > Project Announcements
Arcade Bones (Marquee & Dashboard graphics finalised)
SirPoonga:
--- Quote from: Santoro on December 21, 2005, 07:11:29 pm ---Pixel, why not just screw into the wood from the bottom? The glued bolts look like an accident waiting to happen.
Depends on how thick the wood is there, might not be much to grip to.
Instead of glueing nuts why not use a T Nut? Speaker cabinet builders use them for the speaker holes.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=081-1073
Drill a hole the size of the middle part and pound into wood like a nail.
c64rulez:
Kind of a late comment, but they say better late than...
Just wanted you to know that I think the way you're documenting your project is admirable. I have seen nothing but the quest for perfection, and finally I confess that this project is the reason I became a BYOAC member.
So, if anyone's to blame, it's you ;D
Timoe:
update pics? What color tmold will you be using?
Bones:
Thanks C64.
--- Quote from: timoe on January 21, 2006, 12:18:53 am ---update pics? What color tmold will you be using?
No updates at this moment. I had a hand operation two weeks ago and still recovering. Hoping to return to construction in a few weeks.
There is very little left to actually do. I need to finalise my marquee and dashboard graphics then I will attach the t-molding (black), and we are pretty much done.
There will still be sideart but I am not treating this as a priority at this time.
danny_galaga:
now to the HARDEST task- condensing this thread down to 3 pages or less ;)
