Main > Project Announcements
Arcade Bones (Marquee & Dashboard graphics finalised)
Pages: << < (108/135) > >>
Bones:
--- Quote from: Jess-- on November 25, 2005, 05:21:51 am ---with the magnets being exposed the way they are you may run into problems with your screen if they are too close (funny colours etc)
Don't bucking worry, she'll be right mate.
I got bucking magnets so it shouldn't be a bucking problem.
*Edit- You were right about the actual placement of these speakers being between the CP and monitor. I measured them and the closest distance to the monitor is 8 inches.
M3talhead:
Wait, wait, wait....!!
You're going to tell me that 'Bones actually has class??
That this thing might actually turn out good!??!?  ;)
DrewKaree:
Never let it be said that Bones is a classy guy.  I've met some people worse than him that have projects turn out right.  Class has nothing to do with it.  He's probably afraid if he doesn't finish it, the wife won't let him live down "another one of those stupid projects that prevent you from doing some real work around the house".
--- Quote from: BrokenBones on November 25, 2005, 01:56:31 am ---
Once the box is painted I can finally walk away from this dreaded painting task which has now taken about ten times longer than it should have.... ::)
I'll have that HVLP sprayer write-up finished soon.  My time frame is about a month after you need it ;D
Bones:
--- Quote from: DrewKaree on November 25, 2005, 09:10:59 pm ---I'll have that HVLP sprayer write-up finished soon.  My time frame is about a month after you need it ;D
---smurfette---
Bones:
Today as planned I got some help and lifted the monitor into it's final resting place. Somewhere in my sty of a garage are the right size screws to fix the monitor into place but I can't find them, so for the moment the monitor is held in place with a single cable tie.  ::)
Also did some work on the CP box but it was too damn hot in the sun so I found some other stuff to do which included installing the monitor controls (again accessed through dashboard), and a few other minor things.
Had enough for today so hopefully the weather will hold out for more sanding and painting tomorrow.
Go to full version
