Main > Project Announcements
Arcade Bones (Marquee & Dashboard graphics finalised)
Bones:
Saturday & Sunday update.
I am pleased to announce that construction is pretty much finished.
This week I fixed the fit of my coin door, mounted the speaker remote control, adjusted the height of the monitor glass and did a lot of puttying and sanding.
I have also been busy making the speaker grills that fit on the marquee shelf. I will put together a DIY speaker grill tutorial and post it here when they are finished in approximately 1 week.
I don
Bones:
Mounting of remote control.
DrewKaree:
--- Quote ---
You need to dump a bag or twelve of sand on your driveway and fill in those gaps. ;D
Bones:
--- Quote from: DrewKaree on September 12, 2005, 01:35:24 am ---You need to dump a bag or twelve of sand on your driveway and fill in those gaps. ;D
Yeah, I got problems.
I was going to clean the drain but the driveway is trying to fall forward and I know I won't get the drain cover back on if I mess with it.
The drain is filled with sawdust, Lexan shavings, screws, putty, wire etc etc etc. If you could somehow remove and re-assemble this material to it's former state, you could build a miniature and fully functioning Arcade Bones and probably also get a six pack of VB from all the dregs poured down there.....
paigeoliver:
What is the indentation for? To insure that the machine will be hard to transport!! ;D
