Main > Monitor/Video Forum
Wall of monitors
<< < (2/2)
ChadTower:
Heat heat heat heat heat.
paigeoliver:
You probably won't like the prices, it will be cheaper just to buy a projector.
RandyT:
....And, you'll need 12 monitors to get the proper aspect ration (4:3)
Paige is right.  Just the controller required to carve up an image and put it out to the video wall will cost more than a very nice DLP projector.
RandtyT
ericball:
--- Quote from: RandyT on April 17, 2005, 04:24:47 pm ---....And, you'll need 12 monitors to get the proper aspect ration (4:3)
Actually, no.  You need to use the same number of monitors in both directions, e.g. 4, 9, 16, 25... because the tubes themselves are the correct aspect ratio.
Navigation
[0] Message Index
[*] Previous page
Go to full version
