Author Topic: SPINNER/ STEERING WHEEL. Can it, has it been done?  (Read 5245 times)
rackoon
  • Last login:July 28, 2023, 02:29:36 pm
  • I EAT PENCILS!
« on: April 12, 2005, 02:26:38 pm »
Ok, Ok, I know this might sound stupid, but hear me out.
    Why not mount the spinner in the front middle of the cp and find a way to mount a steering wheel to it. When neither is in use the spinner knob could have a cap placed over it. Or, have the spinner stem recessed.
   This idea seems so simple that it must already be in use.
Am I missing a mechanical problem that would not make this work.
   For example: I know that a steering wheel would probably break a spinner stem. But, why couldn't a steering wheel be modified to have a spinner mounted to its stem.
 Furthermore, the spinner could be mounted at say 30 degrees (maybe) in order for the steering wheel to be angled properly.
    If this idea is stupid, just dismiss this post as the ramblings of a delusional game freak who sat to close to the TV as a chiled. (actually we rarely had a TV because it was seen as an INSTRUMENT OF THE MAN, USED TO CONTROL YOU.)
    Sounded funny as a kid who just wanted to watch Scooby-Doo. But now! after the epic trial of (Scooby V's the state of California) and the landmark legislation that followed, I guess cartoons do have subliminal messages telling me to vote for Nixon as king.
    I THINK SOMEONE SPIKED MY COFFEE. OH, WAIT IT WAS ME.
They treated me like an animal and that's what I became.
Stingray
Re: SPINNER/ STEERING WHEEL. Can it, has it been done?
« Reply #1 on: April 12, 2005, 02:37:50 pm »
It's been done. Someone on ebay sells spinners with a steering wheel attachment pretty often. I'm too lazy to search up a link for you.
-S
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: April 12, 2005, 02:38:46 pm »
Did you post this in the spinner thread and then post it here, or did you post it here and then add it to the spinner thread.
Probably, it's not an original idea (I remember it years ago, and don't remember anyone actually doing it.)
Lots of steering wheels were geared whereas most spinners were not, but I don't know if that's the biggest obstacle.
oldsage
  • Last login:December 19, 2005, 09:11:47 pm
  • Does SHMIGRUB ring any bells??
« Reply #3 on: April 12, 2005, 02:42:18 pm »
And i thought i was delusional...
...Anyway, it sounds cool, but has a couple of very obvious flaws:
How would you connect the wheel???
I wanna see you try... That would be a nice patent if you could think of one...
And even if you manage that, playing spinner games when the spinner is mounted at 30 degrees on the edge of your cp, isn't that much different from playing with a keyboard...
You could do it, it won't be worth it...
BTW, the first sentence is aimed at your last paragraphs...
I had a cool sig once... But it had to go because of *someone*... You know who you are!
Chris
    • Chris's MAME Cabinet
« Reply #4 on: April 12, 2005, 02:44:33 pm »
The biggest obstacle is that spinners have very narrow shafts not likely to hold up to the weight of an arcade wheel or the stress of use as a wheel.    You would have to use a light plastic wheel and use it gently.
--Chris
--Chris
Stingray
« Reply #5 on: April 12, 2005, 03:08:42 pm »
--Chris
Fairly sure that's how the one I refered to in my earlier post works.
-S
Chris
« Reply #6 on: April 12, 2005, 03:15:27 pm »
If someone wanted to try this, the playground steering wheels they sell at Home Depot might be light enough for a try...
--Chris
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: April 12, 2005, 03:31:54 pm »
-S
He's off E-bay now - Here's the link (not an endorsement): http://www.mamespinner.com/
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
« Reply #8 on: April 12, 2005, 03:34:59 pm »
I saw those things... they are cool!
namedos
  • Last login:January 04, 2023, 06:18:13 pm
« Reply #9 on: April 12, 2005, 04:24:18 pm »
Yeah but they have been out of stock for the last four months.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #10 on: April 12, 2005, 04:40:20 pm »
I've always thought the same thing. Games like Pole Position use free-spinning optic wheels, much like a Tempest spinner. I don't know which ones would use a geared system?
NO MORE!!
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« Reply #11 on: April 12, 2005, 09:02:17 pm »
Hmm Ive got an arkanoid spinner around here somewheres...should see if that mite hold up
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #12 on: April 12, 2005, 11:12:39 pm »
NY_in_TX did something similar on his.  It is mounted on the front of the panel but there is no reason it couldn't be put on top.  Problem is, you'd have to seriously modify your spinner to fit the shaft.
http://forum.arcadecontrols.com/index.php/topic,7170.0.html
Next I'll be on fries, and that's when the big money starts rolling in.
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: April 13, 2005, 07:44:08 am »
Indy Heat, at least that I know of.
seanp
  • Last login:January 05, 2015, 12:48:13 pm
  • Dreamcast / PC Mame in progress
« Reply #14 on: April 13, 2005, 12:50:05 pm »
I've been thinking of how to do something like this.  Let me see if I can explain my idea.  You have a spinner with a rubber knob, 1.5" in diameter.  You get a small steering wheel (I'm thinking ones like the super sprint cabs), and you attach (glue? weld?) a connector bracket that has a circular 1.5" hole and with clips or bolts that attach it to the knob.  This way you can use the regular spinner for spinner games, and then throw on a couple of wheels for racing games without too much modification.  Any thoughts on why this wouldn't work??
-Sean
Clones are people, two.
RayB
  • There's my post
    • RayB.com
« Reply #15 on: April 13, 2005, 02:30:46 pm »
-Sean
Yeah, it's already been said that the axis for a spinner isn't strong enough to withstand the torque that would be applied if a wheel were attached (and the subsequent use of the wheel).
I think the solution here is to find a Pole Position or Sprint wheel, and then design it such that you can remove the steering wheel and attach a knob. Kinda same thing you're talking about, but backwards. This way you have the strength needed for when it's used with the steering.
NO MORE!!
melarky
  • Last login:July 12, 2020, 12:49:22 pm
  • If I could be any animal, I would be a llama
« Reply #16 on: April 13, 2005, 02:32:59 pm »
is there any reason not to make the shaft bigger (obviously one would have to fabricate their own spinner), but other than that, is there a technical reason?  Does going thicker make it not spin long enough or does it feel strange with a knob?  Just curious as to why it would matter.
Xiaou2
  • NOM NOM NOM
« Reply #17 on: April 13, 2005, 02:38:27 pm »
 Well, the thicker the shaft - the less it will spin freely -  and,  more importantly... you will need a Lot more weight (like 4times as much!) added to the flywheel to make it feel weighty and correct.
 I actually made a spinner from a thick rod and rollerblade bearings once.
  As for the comment about making a light wheel... its just not gonna feel like a wheel then.   It will feel like spinning a feather arround - and wont travel with as much speed and momentum.
 As said, if the shaft is too thin, and the wheel too heavy and or large, you will most likly bend the shaft from the leverage that is generated.
 Also as said, very important to use a geared system for higher resolution.
 Mounting a knob to a arcade wheel will proove very hard to spin as a knob, most likely..
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #18 on: April 13, 2005, 03:39:01 pm »
Yeah, it would be harder to get the spin to feel right with a bigger shaft. But then you could use this:
Well, the link is not working so here is a model # and pic. Summit Racing Model# SUM-G7857
« Last Edit: April 13, 2005, 03:41:46 pm by nostrebor »
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
« Reply #19 on: April 13, 2005, 06:50:55 pm »
Why not rig it with an elastic or other band like this? This would not put as much strain on the spinner shaft. The Wheel should be detachable so the spinner could be used normally as well. Some spinner knobs come with a groove that looks made for such a purpose.
97.4 percent of all statistics are full of crap.
rackoon
  • I EAT PENCILS!
« Reply #20 on: April 14, 2005, 06:50:01 pm »
I have given this some thought and have come to the conclusion that a metal plate would needed to be installed with circular slot with recessed bearings around the stem.
   These bearings would take the abuse of wild game play and the stem wouldn't have any force on it at all.
 This seems like pretty complicated soluton. I think a detachable PC steering wheel that plugs into the usb port would be the best solution because a steering wheel needs to be mounted vertically.
elvis
  • Last login:April 13, 2023, 05:31:03 pm
  • penguin poker
    • StickFreaks
« Reply #21 on: April 14, 2005, 06:53:36 pm »
That's what I'd do.  That way you can use the biggest, baddest, most heavily reinforced wheel you want that will take any abuse, and know that your spinner is safe and sound from harm.
You'd need to ensure that you've got a 1:1 ratio on your shank radii of course.
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #22 on: May 16, 2005, 12:20:28 am »
Instead of trying to mount a steering wheel on a spinner
why not take a steering wheel control and make the wheel interchangable with a spinner knob?
Then you won't have to worry about the durability
Anyone ever tried?
dphirschler
  • Last login:February 10, 2021, 10:32:54 am
    • dphirschler homepage
« Reply #23 on: May 16, 2005, 09:15:33 am »
Have you ever played Tempest with the steering wheel?  It's fun.  Maybe just forget the spinner and have a steering wheel full time.
Darryl
