Main > Everything Else
Web site newbie help.
GameOver:
--- Quote from: cholin on April 10, 2005, 06:56:35 pm ---Guys, any web designer will dis Frontpage to the ground. Use Macromedia Dreamweaver.
I've tried Dreamweaver, it works great. And as I web designer I absolutely trust and respect your opinion. BUT - I would argue that for a generation of slackers brainwashed on MS products, the learning curver on MS FrontPage is way shorter than Dreamweaver. The FrontPage interface is nearly identical to other Microsoft products (not saying that's great) which means most anyone who can use a Windows PC nowadays can learn FrontPage relatively quickly.
Trimoor:
Frontpage is absolute crap. It doesn't even follow W3 standards. You might as well close your eyes and imagine you had a web page. The best thing to use is a text editor. You can find tutorials at http://www.w3schools.com/
If you must use a program, try something like HTML-Kit. It generates very clean XHTML compliant code.
Whatever you do, NEVER write IE only pages or scripts. You will be flamed mercilessly.
Jabba:
--- Quote from: TOK on April 10, 2005, 05:21:26 pm ---Lots of good info on your build on your page. You have a bunch of broken image links in the control panel section. From about 1/4 to halfway down the page, none of the images show for me.
Thanks TOK...ME Bad. I haven't been to that Website in a while. I noticed the same thing. Should be corrected soon...
Jabba:
--- Quote from: Trimoor on April 10, 2005, 08:31:03 pm ---Frontpage is absolute crap.
cholin:
If money's a factor, lean towards HTML-Kit, PHP Designer 2005, and other free programs. There was one with the word "build" in it, but I forget.
