Main > Everything Else
PC EXPERT NEEDED!
Pages: << < (3/3)
RayB:
--- Quote from: SOAPboy on April 11, 2005, 10:29:26 am ---And those "auto off" things on mobos.. generally only kick off if its at boil point, and thats WHEN they work..
Well my overheat shut-off worked flawlessly, over and over. That's how I eventually figured out it was overheating. I removed the heatsink. Saw I had put it on wrong (needed to be turned 180'). Add a layer of new silver compound. Put the heatsink back on correctly, and now that same chip is still running, but running cool.
~Ray B.
DrewKaree:
--- Quote from: RayB on April 11, 2005, 09:38:20 am ---
The thing about AMD chips, is that there is only 1 way you should put the heatsink on, but it's POSSIBLE to put it on backwards.
Explain this some more and perhaps link to a few credible sources, as that has to be one of the most ridiculous sounding things I've heard since....you could get pregnant from a dirty toilet seat.
Your compound melted/burned away, and all you did was turn it 180o and that solved it.  HOW?  It's a heatsink.  Its purpose is to sit on top of your processor and a thin layer of compound and wick heat away.  How on God's green earth does turning it in half a circle make it wick heat away better?
Pages: << < (3/3)
Go to full version
