Main > Everything Else
Anything special about changing snow tires?
Jabba:
Thanks guys,
Had a better look at the tires. No signs of any chalkmark or any signs of arrows pointing anywhere. ???
I'll be marking those snow tires before I take them off.
I'll check the manual. It is a G35, the rims do allow for airflow, so I'll check extra special.
Any other ideas? Can the tread give me any hints?
RayB:
MOST tire treads are designed to be identical no matter which side you mount them.
whammoed:
--- Quote from: Jabba on April 09, 2005, 10:37:42 am ---Do they need to be re-balanced?
Yes. Rarely do you put a tire on a rim and it is perfectly balanced although occasionally it does happen.
Jabba:
--- Quote from: whammoed on April 11, 2005, 11:53:31 am ---
Yes.
whammoed:
--- Quote from: Jabba on April 11, 2005, 12:03:30 pm ---
Yes.
