Main > Everything Else
animated gif help / Post # 800
Pages: << < (2/3) > >>
TalkingOctopus:
--- Quote from: Shape D. on April 06, 2005, 01:53:00 pm ---
--- Quote from: Peale on April 06, 2005, 01:51:14 pm ---What are you opening it with? A lot of programs will just display the first frame.
ms paint, yeah I know insert lame comment here.............
Try opening it in internet explorer.  It will be animated if it saved right, which I think it probably did.
SirPeale:
MS Paint doesn't have any animation utilities, so you won't see the animation.
If you have a larger image that you need to resize, there are utilities available.  Heck, there are some web-based utilities available.  I did it with my Superman avatar way back when.  I forget what the site was that I used, though.
Shape D.:
--- Quote from: TalkingOctopus on April 06, 2005, 02:02:55 pm ---Try opening it in internet explorer.  It will be animated if it saved right, which I think it probably did.
yep, its animated there. is there anyway to use it as an avatar though?
DrewKaree:
Yes.  You must e-mail it to me, I'll make it animated for you, and send it back to you.
It's my board name AT gmail DOT com.
Shape D.:
Sweet deal, Thank you.
Go to full version
