Main > Main Forum
Ground Limits?
Pages: << < (2/2)
CPickler:
awesome, thanks
NoOne=NBA=:
Oops.
The CAT-5 I have is 24 gauge.
I have used 28 gauge, but it was for 9-pin (Atari/Commodore/Genesis-style) connectors.
I didn't have any problem with that either though.
Just make sure that the wire you buy will work in the disconnects with two strands of it.
If a single strand is a little too loose, you can double it over before crimping it.
If two strands won't fit, you'll have a hard time daisy-chaining.
CPickler:
yeah the two strands not fitting is my concern
SteveJ34:
(2) wire strands should fit just fine into a .187 or .250 disconnect assuming you are using 20-22 guage wire....
CPickler:
cool, thanks.
Also, I ordered all the connectors from Happ controls, and I went to Home Depot tonight.  Found everything I ordered (except the wire) for much cheaper.  And I could have had it tonight.
Ohh well... live and learn.
Pages: << < (2/2)
Go to full version
