Author Topic: Strange Question  (Read 1270 times)
Cutty
  • Last login:July 23, 2009, 10:48:30 pm
  • Cabin Cruiser
Strange Question
« on: April 03, 2005, 04:07:26 pm »
Been seriously researching building my own cabinet for a while now, want to make sure i have everything figured out before i start, but recently something came to mind. What do you guys have for an exit button for games? I have yet to see this mentioned anywhere. I was thinking the best thing would just be an arcade button like on the side or underneath somewhere. Any suggestions?
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
Re: Strange Question
« Reply #1 on: April 03, 2005, 04:09:48 pm »
I think the answers fall into 3 categories:
(1) visible admin buttons on the CP
(2) hidden admin buttons
(3) shifted multi-controller functions.  Like "To exit: while holding Joystick 1 down, press the player 2 button and rub your tummy"
-- Chad Tower
walls83
  • beer is good
« Reply #2 on: April 03, 2005, 04:10:34 pm »
thats what about everybody uses.
Cutty
  • Cabin Cruiser
« Reply #3 on: April 03, 2005, 04:17:24 pm »
Thanks guys i think thats what ill do, never thought about it until i was working on the front end.
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #4 on: April 03, 2005, 04:40:45 pm »
I have a "shift" button on the side of my control panel box, its on the I-Pac as P2 button 8, than I use that + one of the other buttons for admin. Its black so it blends in, on the side so dosn't get hit, and not used in play so no accidental exits :).
paigeoliver
  • Awesome face!
« Reply #5 on: April 04, 2005, 07:14:33 am »
Previous cabinets have used every imaginable kind.
Current cabinets.
Cocktail. Has a microswitch behind the left coin return button on the coin door.
Big wooden cabinet. Has enter, tab and escape buttons on the panel. This panel was pre-drilled by a previous mamer, if I had done it myself then they wouldn't be there. This cabinet also has 2 pinball buttons on each side (also pre-drilled, I wouldn't have done those myself either), which I seem to fairly often remap as service switches, pause buttons, throttle and such.
Giagantor cocktail. I'll probably do the coin return switch trick again.
Fuzzguitar
  • Last login:November 26, 2012, 12:15:34 am
« Reply #6 on: April 04, 2005, 09:47:13 am »
I don't have any admin buttons whatsoever.
P1 and P2 together (esc) with an Ipac are all I need.
They are near each other of course but have never once been accidently pressed even with little kids bashing away at games.
The nature of having a shift button makes esc harder to trigger as you need to momentarily press it before the other function.
"My cab is nearly finished, no really I swear!"
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: April 04, 2005, 11:09:55 am »
I'll be hiding mine on the TOP, in recessed holes.
NO MORE!!
