Author Topic: Arcade Depot Cocktal 11 inch Control Panel Suggestions  (Read 846 times)
dweebs0r
  • Last login:December 16, 2023, 04:49:40 pm
  • Ascendo tuum!
    • Jodys Garage Arcade
« on: April 03, 2005, 09:02:55 am »
Hello,
I am in the process of purchasing an arcadepot.com cocktail kit with the 11 inch control panel sides.  The sides are currently set up similar to the whammocade cocktail.  Here is a pic:
Would you guys do anything different?  Any suggestions?
If I should decide to change them, would anyone want to purchase these panels?
Also, anyone know what Happs part number this coin door is?
Thanks for the help!
-Dweebs
« Last Edit: April 03, 2005, 02:00:18 pm by dweebs0r »
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
Re: Arcade Depot Cocktal 11 inch Control Panel Suggestions
« Reply #1 on: April 03, 2005, 01:45:03 pm »
First thing I would change is the button layout, it's really bad.  And then the third long panel with the joystick on the wrong sides of the buttons?  Unless someone is a lefty, not the best layout either
You need to decide how many games out there require a trackball on a vertically oriented game, if you are a Centipede fiend then yes, you need it, otherwise maybe consider leaving it off and laying the buttons out better.
dweebs0r
  • Ascendo tuum!
« Reply #2 on: April 03, 2005, 01:56:43 pm »
Actually the panels will be reversed when mounted.  Not the best picture.
The third control panel has 2 "Street Fighter" style setups (1 joy + 6 buttons) and then a 4 way and a spinner in the middle.
The other two are setup similar to the world famous Whammocade -- check the link --> (http://web.tampabay.rr.com/whammoed/whammocade/whammocade.htm)
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #3 on: April 03, 2005, 06:00:49 pm »
I don't think that is a Happ coin door.  Maybe Williams?
tommy
« Reply #4 on: April 03, 2005, 06:43:45 pm »
Yup thats a williams coin door , looks like my moon patrol door, why do you need the part number i have parts or the whole door if you need it.
dweebs0r
  • Ascendo tuum!
« Reply #5 on: April 03, 2005, 06:46:35 pm »
Just curious.  I was gonna check the price of a brand new replacement, in case I am not happy with the way this one looks installed.
Is there a Happ coin door that has the same measurements?
So do you guys think I should keep the control panels laid out as is or try something else?
-Dweebs
« Last Edit: April 03, 2005, 07:16:32 pm by dweebs0r »
