Main > Everything Else
Tire Inflation
Bones:
--- Quote from: DrewKaree on April 02, 2005, 09:00:55 pm ---Besides, Bones can't even stay on his bike, "tyres" or not, and mebbe he sustained a hit to the head in his assident, so what does he know? :P ;)
Ahh yes...... this is true.
And from that day forward, I now always pressurise my tyres as per the vehicle manufacturer recommendations.
SirPeale:
--- Quote from: JCL on April 02, 2005, 09:41:13 pm ---Often times the side of the tire has the maximum inflation, not the recommended inflation. The max inflation is needed for the max weight. This would be unusual for most conditions.
I figured it was something like that. The language on the tire tipped me off, ie 'Max PSI' not 'Recommended PSI' or whatnot. It's not ride I'm so concerned with, as I am tire wear. Too much, and the center wears out. Too little, the sides. I want the right amount so it wears evenly.
Zakk:
44 in front and 35 in back? Are the tires matched? Perhaps only the most worn ones were replaced at some time. I always believe in getting a matched set of tires with equal tread (really helps on slick streets).
