Author Topic: Trackballs and Spinners without mice  (Read 1465 times)
MajorLag
  • I'd say the same about a good chunk of the people posting in PnR, including myself.
  • Last login:July 11, 2013, 03:54:10 pm
  • Damn you party liquor!
« on: April 01, 2005, 05:36:04 pm »
I'm doing research for my future MAME cab and I wanted to include 3 trackballs and at least 4 spinners (trackballs aren't built into the panel, they're addon). It seems that the only way to have that many trackballs/spinners is to install special software to allow for more then one mouse, and only MAME Analog+ recognizes these extra mice anyway.
I was thinking, MAME has digital inputs for the trackball/spinner controls that move a set amount when a button is pressed. Would it be possible to rig a trackball/spinner to use these inputs directly, without encoding a mouse-compatable signal? Basically juse send the button press whenever a gap is encountered on the wheel, or something?
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
Re: Trackballs and Spinners without mice
« Reply #1 on: April 01, 2005, 05:42:48 pm »
I suppose you could use a couple of these
http://www.ultimarc.com/optipac1.html
or maybe just one + a mouse hack
Features:
    * USB Mode: One USB cable handles up to two trackballs and 4 spinners/rotary joysticks.
    * Serial mode: Two independent serial port inputs to accomodate two trackballs and 4 spinners/rotary joysticks.
« Last Edit: April 01, 2005, 05:45:38 pm by IntruderAlert »
MajorLag
« Reply #2 on: April 01, 2005, 05:52:53 pm »
I was just looking at those. And while it looks like a great product, the trackballs and spinners still act as mice. In fact, if you read the features list, it specifically states "Also works in two player mode (two USB mouse devices) using MAME ANALOG+". The faq says that the serial one will work in the official MAME, but it only supports 2 trackballs, and I was really hoping for 3.
JB
  • Last login:October 21, 2005, 10:56:01 pm
« Reply #3 on: April 01, 2005, 09:06:49 pm »
You'd lose the entire point of using trackball/spinners. May as well just stick joysticks in.
MajorLag
« Reply #4 on: April 01, 2005, 09:35:58 pm »
You think so? I wasn't sure. I figured that if you spun the wheel, it'd by like hitting the button a bunch of times really quickly, so it'd be faster then spinning the wheel slowly, and would feel about right with th right settings.
I suppose I'll just have to live with 2 trackballs.
JB
« Reply #5 on: April 01, 2005, 10:32:36 pm »
Hypothetically you COULD code a variant of MAME to use the keypresses as bits in a serial data stream instead of distinct control inputs, but no one has. And I seriously doubt the PC keyboard protocol is up to the task.
markrvp
  • NFL Expert
« Reply #6 on: April 01, 2005, 10:43:40 pm »
Out of curiosity, what games use 3 trackballs simultaneously?
MajorLag
« Reply #7 on: April 01, 2005, 10:53:25 pm »
Rampart.
markrvp
  • NFL Expert
« Reply #8 on: April 02, 2005, 05:30:11 pm »
Rampart looks cool.  I've never played it.  Let us know how the cab is coming in Project Announcements.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #9 on: April 02, 2005, 07:56:11 pm »
There's a joystick version of Rampart.
(i think)
NO MORE!!
JODY
  • Last login:January 19, 2024, 05:06:29 pm
  • After a long delay...the arcade is underway!
« Reply #10 on: April 02, 2005, 08:23:32 pm »
(i think)
Yes, but I find the trackball version much easier to control.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #11 on: April 02, 2005, 10:30:24 pm »
Ask U_Rebel_Scum about support for a 3rd mouse.
IntruderAlert
    • Intruder Alert
« Reply #12 on: April 04, 2005, 02:55:41 pm »
Why couldn't you use the optipac in serial mode and hook up a third trackball on the USB with a mouse hack?
MajorLag
« Reply #13 on: April 05, 2005, 01:20:27 am »
Because as far as I can tell that would require Analog+ and extra drivers, which I'd rather avoid.
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: April 05, 2005, 07:38:35 am »
Pretty sure standard MAME (later build) under Win98 supports two mice in USB mode without Analog Plus.
Also pretty sure the Opti-Pac in serial mode reques DOS MAME and different drivers for the two trackballs.
Not sure why you seem to have a problem with two Opti-pacs in USB mode or one USB opti-pac and a USB mouse hack and running Analog Plus to get three trackballs.
It's a simple solution to your problem, and I don't think there's another way (well, you could mod the MAME source yourself to make it work and re-compile, but I don't see the point).
IntruderAlert
    • Intruder Alert
« Reply #15 on: April 05, 2005, 08:40:14 am »
So you could just run everything  USB?
I wasn't sure
That sounds like the best solution to me too
Tiger-Heli
    • Tiger-Heli
« Reply #16 on: April 05, 2005, 08:43:55 am »
I wasn't sure
At least with Analog Plus you can (up to eight mice, for that matter)
MajorLag
« Reply #17 on: April 05, 2005, 03:37:36 pm »
I just don't care for the idea of having to use a non-official MAME build. I suppose I'll have to though if I want 3 trackballs.
Tiger-Heli
    • Tiger-Heli
« Reply #18 on: April 06, 2005, 08:24:43 am »
I always say this and no-one listens to me (yes I meant the NBA guy, j/k)
Analog Plus isn't a bad build (if Urebel would update it, hint, hint . . .), but you don't have to run everything through it.
Run all your regular joystick/single trackball games through official MAME and then use Analog Plus for Rampart and CABAL and all the dual trackball stuff.  Use a frontend that supports multiple emulators from the commandline and you won't even notice that it's switching to a different MAME version.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #19 on: April 06, 2005, 04:34:53 pm »
I know, I know. :-[  But with Real Life (and all the new toys) ... slowly plugging away has been really slow. Sorry guys. :-\
WIP
Robin
Knowledge is Power
