Author Topic: Can anyone in CT with a std OR med res monitor help me test a board??  (Read 590 times)
nipsmg
  • Last login:May 06, 2024, 12:59:59 pm
  • ROONEY!! ERRGH!!
    • Arcadia
I bought a golden tee Fore! 2004 board off of ebay, and I've been trying to test it using a JROK RGB-> NTSC convertor, but all I get is a screwed up picture.  He even says the board isn't compatible with ALL std res arcade boards, so that may be why there's an issue.
Does anyone in CT have a MED Res or a std resolution arcade monitor that wouldn't mind plugging this board in for me and testing it out on their monitor?  It would be GREATLY appreciated.
Thanks in advance if anyone is willing to help.
« Last Edit: April 02, 2005, 10:49:32 am by nipsmg »
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Can anyone in CT with a std OR med res monitor help me test a board??
« Reply #1 on: April 02, 2005, 10:54:16 am »
please?    :'(
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #2 on: April 02, 2005, 02:58:23 pm »
ok I'll give someone $20 to test it? :)
SirPeale
  • Green Mountain Man
« Reply #3 on: April 02, 2005, 02:59:59 pm »
I'd do it, but I'm in Vermont.  Unless you want to mail it up here.
Is it a JAMMA board?
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #4 on: April 02, 2005, 03:11:34 pm »
Yeah, I've actually got to get it tested ASAP so I can let the seller know if it works or not, he guaranteed it working.
I was trying to find someone local..  unfortunately nothing yet.  If I don't get responses by tomorrow I'm going to go down to the local distributor and probably get overcharged for a std res monitor, but I may not have a choice at the moment.
Thanks for the offer however peale.
SirPeale
« Reply #5 on: April 02, 2005, 03:18:38 pm »
Jeeze, don't do that.  Put a message up on RGVAC stating what you're looking for.  There's enough arcade guys in CT that *someone* must be able to help you out.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #6 on: April 02, 2005, 03:27:12 pm »
That's not a bad Idea.  I just did that.  Hopefully I'll get a response. *shrug*
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:December 23, 2023, 07:05:04 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #7 on: April 02, 2005, 09:31:59 pm »
I have a K7400 in central NJ if you want to take a drive.  (zip 07920)
