Author Topic: Mini-PAC  (Read 2511 times)
Searcher7
  • Last login:June 21, 2009, 10:45:22 pm
Mini-PAC
« on: March 28, 2005, 05:29:38 pm »
I'm about to order a Mini-PAC and intend to interface it with an original arcade trackball(from Missile Command), and/or my original arcade spinner(from Arkanoid).
Considering this, does it make a difference if I order it with a "Ultimarc T/B Harness" or a "Happ T/B Harness"?
Also, can anyone tell me what the difference is between the "Standard" and the "Opti", as far as the physical hardware received?
Thanks a lot.
Darren
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Mini-PAC
« Reply #1 on: March 28, 2005, 08:19:43 pm »
Since nobody seems to be able to help you, I think I should add that its always best to ask Andy, because if anyone know's his own hardware, its the creator.
Flinkly
Re: Mini-PAC
« Reply #2 on: March 28, 2005, 10:13:15 pm »
at this time, all the actual minipac boards are the same.
Searcher7
Re: Mini-PAC
« Reply #3 on: March 29, 2005, 06:11:10 pm »
The reason I asked is because I have a lot of wiring and just wanted to get what I needed.
Perhaps a better way to phrase the question is why does the "Opti" allow a mouse input and the "standard" doesn't?(I'm just trying to figure out the hardware differences).
And just to make sure. There is no better solution than the Mini-PAC for a large number of single player games, correct?
Thanks.
Darren
cholin
    • Nilok Productions
Re: Mini-PAC
« Reply #4 on: March 29, 2005, 08:12:25 pm »
Well theres no better solution as of now, but I dont see what you mean for opti.  Is that just the board that you can buy says opti?  That's just a harness.  All the boards are the exact same, but what Andy does is sells you connectors too for specific things, so you save an hour's work.
Searcher7
Re: Mini-PAC
« Reply #5 on: March 29, 2005, 10:00:29 pm »
cholin
    • Nilok Productions
Re: Mini-PAC
« Reply #6 on: March 29, 2005, 10:08:33 pm »
Yes, basically.  What Im saying, is that no matter which one you pick, you will get the same board.  If you want a wiring harness, its gonna cost extra.  If you want a special wiring harness (trackabll) its gonna cost u even more.
If you buy the 29 dollar board, and BYO wiring harness, you still get the functionality of the trackabll, just you had to make your own wires.  He's selling the wires basically.
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Mini-PAC
« Reply #7 on: March 30, 2005, 12:39:01 am »
The wires, the connectors, and most importantly, the labor time.  How long would it take you  to split apart an IDE cable, solder longer leads onto all the wires, and attach quick disconnects to the end of each wire?  How much is your time worth?  I know I'm slow at that stuff, and lack of time is the biggest thing keeping me away from cab building now, so it doesn't seem so expensive to me.  Folks with more time and less $$ might be of a different opinion, though.
cholin
    • Nilok Productions
Re: Mini-PAC
« Reply #8 on: March 30, 2005, 07:01:24 am »
Im the folk with more time and less money, and believe it or not, I dont mind doing that kind of stuff.  If I had the parts he used, I would probably sell the harnesses for wire charge + 5 bucks labour.  I enjoy doing this kind of stuff, which will end up saving me money (not alot, wont kill you if you buy the harness)
Searcher7
Re: Mini-PAC
« Reply #9 on: April 02, 2005, 08:34:07 am »
Thanks.
I have to do some custom wiring, and I'm not using either the Happs or Ultimarc trackball, so I guess homemade is the best way to go for me.
Can anyone tell me what specific board connector/s connect to the Mini-PAC?
Thanks.
Darren
Tiger-Heli
    • Tiger-Heli
Re: Mini-PAC
« Reply #10 on: April 02, 2005, 09:45:37 am »
If it's a missile command trackball it's essentially a Happs.
The Mini-pac wiring diagram is here - http://www.ultimarc.com/mp_inst.html but it doesn't specify any differences for the different types of trackballs.  I think it might be pull-up resistors, but you might want to confirm with Andy.
If you mean the pin headers on the board - They're 0.100 inch centers and you can cut a standard computer HD cable and run it to a terminal block or splice onto it.
Searcher7
Re: Mini-PAC
« Reply #11 on: April 02, 2005, 04:09:33 pm »
Tiger-Heli
    • Tiger-Heli
Re: Mini-PAC
« Reply #12 on: April 02, 2005, 05:43:05 pm »
I've been attempting to figure out why it makes a difference which trackball is used. And I can only assume that it is because of the different optic boards, which means that the Mini-PAC doesn't factor those out.
Darren
I think it has to do with active hi and active lo and pull-up resistors, but I'm not sure at all on this.
Searcher7
Re: Mini-PAC
« Reply #13 on: May 01, 2005, 12:04:33 pm »
Unfortunately, the mini-PAC is now out of the question, because when I e-mailed Andy to ask if he would accept a postal money order, and he replied with the below:
 "We can accept Postal Money Orders but only in GB Pounds. Unfortunately if you are in the USA you will not be able to get one of these.
Okay, can anyone recommend another option for me?
Thanks.
Darren
Kremmit
  • - AHOTW -
Re: Mini-PAC
« Reply #14 on: May 01, 2005, 07:28:13 pm »
Thanks.
Darren
Paypal?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Mini-PAC
« Reply #15 on: May 01, 2005, 07:31:26 pm »
Post a WTB in B/S/T ... maybe someone can tack a MiniPac on their next Ultimarc order.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
Searcher7
Re: Mini-PAC
« Reply #16 on: June 09, 2005, 08:50:45 pm »
I'm still in search of the next best option.
Thanks a lot.
Darren
Tiger-Heli
    • Tiger-Heli
Re: Mini-PAC
« Reply #17 on: June 10, 2005, 11:00:09 am »
www.groovygamegear.com KeyWiz Eco2 (no solder) or GP-Wiz (no-solder) and www.oscarcontrols.com pre-hacked USB mouse interface.
Searcher7
Re: Mini-PAC
« Reply #18 on: July 20, 2006, 10:05:44 pm »
Ok. I now have a couple of Mini-PAC PCBs.
I've noticed how thin the wires are in an IDE cable. Is it plausible to find some sort of extention header(a stand-alone IDE connector) where 20 gauge wires could be attached to each pin?
Thanks.
Darren
Tiger-Heli
    • Tiger-Heli
Re: Mini-PAC
« Reply #19 on: July 25, 2006, 08:59:58 am »
I don't think so, at least I've never seen one.
romperwomb
  • Last login:May 24, 2023, 06:07:43 pm
  • Plick!
Re: Mini-PAC
« Reply #20 on: July 25, 2006, 11:05:20 am »
Thanks.
Pick up some Terminal Strips from Radio Shack.
The IDE wires come in on one side and 20 gauge out the other.
Tiger-Heli
    • Tiger-Heli
Re: Mini-PAC
« Reply #21 on: July 25, 2006, 05:14:09 pm »
See Reply #10 above.  ;D
Searcher7
Re: Mini-PAC
« Reply #22 on: July 25, 2006, 08:30:21 pm »
I'm trying to find a solution around the small wire gauge problem.(I'm used to using 20g minimum on all my projects).
Darren
