Main > Monitor/Video Forum
Inverted Colors
Ken Layton:
Nintendo's inverter board gets it's power from the monitor's main board.
Also remember that Nintendo's inverter board uses a different connector pinout that standard arcade monitors.
Trimoor:
I tried fiddling with it and replaced a cap, but still nothing. I don't have a video amp, and I'm guessing it would cost more than the monitor itself. The inverter board is comprised of 6 transistors, so it is definitely analog.
I took a pic of my scope showing the green signals for both the normal and inverted output, and they look to be proper. This raises more questions. If it's outputting a properly inverted signal, why won't the monitor work with it?
Could I modify the inverter board to work with lower signal levels? How?
StephenH:
Here is what color inversion does to the colors, to see if it is working:
Black <-> White
Red <-> Cyan
Green <-> Magenta
Blue <-> Yellow
Trimoor:
I know what the inversion does, but the monitor displays nothing when I plug it into the inverted output of the inverter board. The scope shows a solid signal on the inverted output as in my pic above, but the minitor will display nothing. The pinouts are correct, the board has power, and I can see a clear signal on each of the pins. What could be wrong?
Ken Layton:
Has the monitor had a capkit recently?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
