Author Topic: Permenantly change an Ultimate to a 4-way?  (Read 841 times)
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
« on: March 20, 2005, 11:44:46 pm »
I have an old, beaten-down Happ Ultimate 8-way stick.  It plays the U,D, L, R really nicely, but the diagnols grind.  I was wondering if anyone has made a cheap and easy (and permenant) 4-way restrictor for such a stick?  It could be located anywhere on the stick, but preferably under the control panel (not above like the old Oscar Controls restrictor plates).  Any ideas?
Lilwolf
Re: Permenantly change an Ultimate to a 4-way?
« Reply #1 on: March 21, 2005, 08:35:16 am »
There are a few ways to do it.
One is the  buy some washers and screw them into the bottom to hit the diagonals.  Getting the right size so that you cant hit the diagonals is the trick, I believe that a nickle was about it... might have been a quarter... some money size)... Also they are rouned (and should really be closer to a tringle).  You might be able to get something to work with some straight metal that can be screwed between each screw terminal at the bottom.
Anyway, take a look at the bottom and try and add some kind of restrictor there.
NoBonus
« Reply #2 on: March 21, 2005, 10:41:24 am »
So you think metal triangles(essentially making a diamond shape on the bottom of the stick) is a good route?  On the bottom of the stick there is that trapezoid actuator... will it be the actuator that makes the hits against the diamond? Or should I try to get the shaft to hit the diamond?  Would the diamond wear out the plastic actuator quickly? Or only over a long time and lots of abuse?
daywane
  • Last login:Yesterday at 09:30:03 pm
  • GRRRR!
« Reply #3 on: March 21, 2005, 11:45:38 am »
NoBonus
« Reply #4 on: March 21, 2005, 11:59:18 am »
Where can I find a good pic of the underside of a Tron stick?
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #5 on: March 21, 2005, 12:39:06 pm »
I've got an Ultimate 4-way base I could sell you..
NoBonus
« Reply #6 on: March 21, 2005, 12:42:01 pm »
I don't have the cash to spend on a 4-way base, but could you post a pic or two of the 4-way base?
Lilwolf
« Reply #7 on: March 21, 2005, 12:53:39 pm »
you know what might work.
« Last Edit: March 21, 2005, 12:55:22 pm by Lilwolf »
Kremmit
  • - AHOTW -
« Reply #8 on: March 21, 2005, 07:37:29 pm »
OK, here's an 8-way on the left, and a 4-way on the right.  (The 4-way is the older leafswitch variety- now you can see what the extra holes on your Ultimate base were for!)  Note the different actuator.
« Last Edit: April 02, 2005, 02:50:15 am by Kremmit »
daywane
  • GRRRR!
« Reply #9 on: March 22, 2005, 08:34:15 am »
left tron   right xenophobe
I can not show the restictors there at work being re prodused
