Author Topic: Can you use an arcade steering-wheel with pc steering-wheel innards?  (Read 1100 times)
RoboG2
  • P&R
  • Last login:August 15, 2008, 10:21:26 pm
I would like to have a sitdown driving cab for newer games (NFSU2, etc.), but would not like to use those pc steering-wheels, as they do not look as realistic as thos found in some arcade machines.  Can you use an arcade steering-wheel (I believe 270 degrees for newer games) with pc steering-wheel innards (pcb, etc.)?  Thanks in advance.
Flinkly
Re: Can you use an arcade steering-wheel with pc steering-wheel innards?
« Reply #1 on: March 20, 2005, 01:57:46 pm »
you could pick up the actual old school steering wheel of ebay, and then figure out how to replace it with your pc steering wheel...other than that, i would say no since technology has changed alot since then.  if you found any old arcade equipment that was compatible with todays equipment, i would be very suprised.
APFelon
  • Last login:May 09, 2023, 08:10:35 pm
« Reply #2 on: March 20, 2005, 01:59:05 pm »
There are products out there that will allow you to use an arcade wheel with your PC. It's a small PCB that operates similar to the J-PAC or I-PAC. Give me a moment and I'll find a link for you...
APf
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #3 on: March 20, 2005, 02:05:07 pm »
ooh, ooh, ooh im super interested in this too. how about using some adapters on that adapter to use the wheel with consoles? force feedback or vibration??
im making a console driving cab right now, and the wheel i have is OK, but i wish it was more sturdy.......
waiting with baited breath!
gnat
APFelon
« Reply #4 on: March 20, 2005, 02:12:26 pm »
Heck, give the A-PAC a look. It has recently been released by arcade control legend Andy Warne and I will personally vouch that his products are top notch.
http://www.ultimarc.com/a-pac.html
Good luck!
APf
isamu
  • Last login:April 27, 2024, 04:23:04 pm
« Reply #5 on: September 11, 2005, 09:22:41 pm »
what about using PC force feedback wheels on a JAMMA pcb?
