Main > Monitor/Video Forum
How do I discharge a monitor with no frame?
Pages: << < (3/3)
AceTKK:
Everything I've read says it's simple to remove the monitor and there is no need to discharge it unless you're going to attempt to work on it.  Just be careful not to touch the anode wire (the one attached to the tube with a suction cup) or any of the capacitors on the circuit board.
-Ace-
MonitorGuru:
--- Quote from: AceTKK on March 20, 2005, 01:16:44 am ---Everything I've read says it's simple to remove the monitor and there is no need to discharge it unless you're going to attempt to work on it.
Pages: << < (3/3)
Go to full version
