Author Topic: Correct jamma psu voltages  (Read 920 times)
bowza
  • Last login:July 08, 2005, 03:04:35 pm
« on: March 17, 2005, 09:02:25 am »
Cant seam to bring anything up in a search so ill ask
What are the correct voltage ranges for the 5 12 and -5 outputs of a jamma PSU
Mine reads 4.9v 11.8 and -5.07
Bowza
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Correct jamma psu voltages
« Reply #1 on: March 17, 2005, 10:46:09 am »
They seem fine.  As long as theyre really close to their voltages, its fine.  Are you having problems with it?
bowza
« Reply #2 on: March 17, 2005, 12:07:33 pm »
I have a system 11 board soul edge that graphics smudge , thought it may be voltage related as a taito Cartridge board works fine, also a standard jamma board works ok.
Thought the system 11 may be less low voltage tolerant
Dave
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: March 17, 2005, 01:38:20 pm »
graphics SMUDGE? What does that mean exactly?
Sounds more like a monitor problem.
NO MORE!!
bowza
« Reply #4 on: March 17, 2005, 04:50:09 pm »
fixed
Replaced psu with one borrwed from the guy I bought the monitor from , now a nice crystal picture, so off to find a nwe psu next.
Cheers all
paigeoliver
  • Awesome face!
« Reply #5 on: March 18, 2005, 08:53:25 am »
Isn't your power supply adjustable? If so then you can just dial the voltage up to the correct 5.1 volts.
Some boards eat more juice than others and will require you to adjust the PSU anyway. I have one board that eats so much juice that my Candy cab can't even get the board up past 4.6 volts (but the new power supply in my Multi-Williams can be dialed up high enough to run it). I can't remember the name of the game at the moment, but it is an old Konami pinout game where you play a round tank, joystick, rotate right, rotate left, and fire
EDIT- Just remembered the name. Strategy-X
