May 08, 2024, 12:42:00 am
If you mess around trying to mount the TB without a plate, you should be able to fit a 3" trackball into a 6" space.
Could you not just build it out slightly to the front X-Arcade/Hotrod style?. The extra space should give you plenty of room to mount your TB on the front and the spinner behind it.
