Main > Main Forum
External mounting of USB Ports/hub
SirPoonga:
http://img.photobucket.com/albums/v472/SirPoonga/cabinet/y_cab10.jpg
http://img.photobucket.com/albums/v472/SirPoonga/cabinet/y_cab16.jpg
For the part mounted on the plexi, that's just the USB ports stolen from one of those header extensions. You know those motherboards that have USB headers and the ports take up an expansion slot. I mounted them directly to the plexi. Then spliced that into a normal usb cable which is plugged into the hub on the inside of the cabinet.
