Author Topic: How do you punch a square hole?  (Read 2625 times)
Hoagie_one
  • Um....whats a cabinet
« on: March 08, 2005, 10:26:19 pm »
I'm gonna need to punch some square holes in my Metal CP for carriage bolts to secure a trackball.  How does one punch clean square holes?
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:37:55 pm
Re: How do you punch a square hole?
« Reply #1 on: March 08, 2005, 10:40:57 pm »
drill a hole on the four corners and use a dremel.  ;)
Free VGA Breakout Cable
Hoagie_one
« Reply #2 on: March 08, 2005, 10:46:09 pm »
gotta be an easier way. Do they make square hole punches?
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: March 08, 2005, 10:58:24 pm »
Holes don't have to be square.  I have had no problem tightening the nuts on carriage bolts with round holes drilled...especially on the trackballs...I remember them (happs and ultimarc) having square holes in them that would lock in the bolt.
Hoagie_one
« Reply #4 on: March 08, 2005, 10:59:44 pm »
holes on my imperial are circle.  I guess I could drill em and them file em a little.
NoOne=NBA=
« Reply #5 on: March 08, 2005, 11:22:54 pm »
Yes, but you're going to need the press they go in.
A machine shop should be able to do it for you, but the cost would probably be a little steep for the few holes you need.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: March 09, 2005, 12:15:40 am »
I use a small square file in metal control panels. Greenlee makes square 'knockout' (a.k.a. "chassis") punches but get out your wallet -- they are expensive!
1UP
  • Token Junkie
    • 1UPArcade
« Reply #7 on: March 09, 2005, 01:05:04 am »
http://www.directron.com/nibbletool.html
I have one of these nibblers, which work pretty well in thin metal and plastic (1/16" or less).  They're more for case modding, so I'm not sure if this would work on a metal control panel.  Also, probably not useful for carriage bolt holes.
My other job...
paigeoliver
  • Awesome face!
« Reply #8 on: March 09, 2005, 01:05:54 am »
I normally just drill the holes round and then either bang the bolts down with a hammer or screw them until they go down flat.
Hoagie_one
« Reply #9 on: March 09, 2005, 07:32:10 am »
use teh bolt to punch the square then....yeah, i'll prolly go that route
XtraSmiley
  • Last login:April 06, 2024, 09:29:46 pm
  • Kill the Big Dog
« Reply #10 on: March 09, 2005, 09:06:56 am »
How big of a hole do you drill to do this?  Also, please post your results, with pics if possible.  I'm going to be doing this to a Space Duel CP soon and don't want to mess it up.  Thanks.
hearingprotectionBIGDOG@yahooBIGDOG.com
Kill the Dog man.
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
« Reply #11 on: March 09, 2005, 09:18:53 am »
It depends on the thikness of the material. My last panel I ruined three hole saws, they were designed for steel, but it was thick. Regardless, I was able to pound the carriage bolts down and tighten. You should have no problem.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #12 on: March 09, 2005, 09:41:30 am »
If it's at all possible to cut an X then you will be able to tighten the bolt down into it creating a square.
NO MORE!!
jcrouse
    • CPViewer
« Reply #13 on: March 09, 2005, 10:18:34 am »
To answer your question, yes. There are square BROACHES. Any industrial supply house (machine shop supplier) will have access to them.
To offer my opinion, as an ex-tool and die maker, drill them round and then file out the corners with a tiny file. I did 12 holes (a cocktail with three cp's) in 1/16 metal cp's in about 15 minutes. It's very simple.
Good luck,
John
XtraSmiley
  • Kill the Big Dog
« Reply #14 on: March 09, 2005, 10:36:13 am »
Cool, thanks man!  Can you just hammer these into the hole?
http://mdmetric.com/dumont/prod3a.html
Kill the Dog man.
GalaxyForce
  • Last login:January 30, 2006, 01:46:46 pm
« Reply #15 on: March 09, 2005, 11:37:00 am »
idealy the broach should be 'pressed' through,  they are made (usually) of high speed steel, and could shatter if you hammer on them.  I have never used one, that is just my opinion.
