Arcade Collecting > Miscellaneous Arcade Talk
Transformer interference in cocktail games?
<< < (6/6)
2PacMan:
Thanks...that site had some pretty good info.  The top link was still down, but i got some good info from the other links.
Thanks again
Stingray:
The first thing you need to learn is how to safely discharge your monitor. That part is pretty much essential. Chad isn't jerking you around, there's lethal voltage lurking around in there. Do a google search on that topic and read up on it.
-S
RayB:
... Yeah but you don't discharge a monitor if all you're doing is twiddling the pots. What he needs is to 1. Open the cab up properly so he has as much access to the pots as possible, and 2. Buy a plastic screw driver.
ChadTower:
Uh, no, you don't stick your arm in something if you don't know where the teeth are.  You just don't.
BTW, I like the idea of jerking and lurking.  It just sounds right.
Silhouette:
I had some transformer problems with a Pac-Man cocktail. I was on the 2nd Pretzel level, and then Megatron just kicked the machine and it shut right off. That guy's a real ass. :(
Navigation
[0] Message Index
[*] Previous page
Go to full version
