Author Topic: Power Connector  (Read 1248 times)
vader
  • Last login:September 23, 2022, 12:22:08 pm
  • I can't breathe in this thing !!
Power Connector
« on: February 28, 2005, 09:53:21 am »
I seen this on someone's cabinet and can't exactly think of the name for it.  It looks like the power connector on the back of a computer power supply, but you would mount in a cabinet instead and it has the rocker switch also.  I wanted this so I can plug a smart strip inside and run on wire from the outside to the wall socket.  If someone know the name for it and a possible link...
Tim
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: Power Connector
« Reply #1 on: February 28, 2005, 11:14:35 am »
You mean like one of these, but with a built in rocker? Never seen one, but you could try calling an electronics supply and see what they say.
vader
Re: Power Connector
« Reply #2 on: February 28, 2005, 11:43:35 am »
Thats it Joy.....while I was browsing I seen someone with that  and a rocker on it also, but I forgot to bookmark it.....will have to start  looking around again
Tim
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
Re: Power Connector
« Reply #3 on: February 28, 2005, 11:48:18 am »
Yeah, I've seen it with a rocker as well.  Keep googling and I'm sure you'll come up with something
-- Chad Tower
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Power Connector
« Reply #4 on: February 28, 2005, 11:51:44 am »
If only Id known about this before.  I was looking through someones MAME site and they had one of these on a PacMan cocktail with a link too.  I bet it was from mouser.com give it a look.
vader
Re: Power Connector
« Reply #5 on: February 28, 2005, 11:53:44 am »
« Last Edit: February 28, 2005, 11:56:02 am by vader88 »
quarterback
Re: Power Connector
« Reply #6 on: February 28, 2005, 11:57:19 am »
That one's bigger than the one I've seen (and that one also contains a fuse which I don't remember seeing) so you can probably get the price down some.
Good luck
-- Chad Tower
cholin
    • Nilok Productions
quarterback
Re: Power Connector
« Reply #8 on: March 17, 2005, 03:27:45 am »
I was remembering something like this, and it's just under $2
[click image for link to product]
-- Chad Tower
cholin
    • Nilok Productions
Re: Power Connector
« Reply #9 on: March 17, 2005, 11:42:28 am »
Actually, I just posted a thread called "Power Entry" and it has a link to the one I want to use from jameco.  Its very cheap, less than a dollar, so I figure, why not add the touch :)  I just had to make sure it was safe.
Steve B.
  • Last login:July 22, 2017, 10:32:41 am
Re: Power Connector
« Reply #10 on: March 17, 2005, 12:44:46 pm »
I don't think I've ever seen one with a built-in rocker switch, but if it helps, what you are searching for is called an IEC socket.
vader
Re: Power Connector
« Reply #11 on: March 17, 2005, 05:09:37 pm »
Yep, they have em with rockers,  I ordered one and wired it up, works like a charm.  Only problem is, I misplaced it....dammit.  Ordered up
another one from mouser.com, this time illuminated.  Woohoo....and FYI, this is called a Power Entry Module.
Tim
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
Re: Power Connector
« Reply #12 on: March 18, 2005, 09:45:09 am »
Hey vader,
That looks like a cool idea - what part# did you order?  Also, I'm electrically-challenged, would I need a 1-pole or 2-pole?
Stevodevo
stevejt
  • Last login:January 01, 2022, 01:21:32 pm
  • stevejt.com
    • My site
Re: Power Connector
« Reply #13 on: March 18, 2005, 11:38:46 am »
I don't understand why you would need that to use a power strip inside your cabinet.  There is no outlet on the inside, so you would have to wire the smart strip to it.  Why couldn't you just wire the smart strip to the current power wires inside and use the current power switch?  If it's a new cab the same thing would work, or wire an outlet inside the cabinet.   ???
Steve
cholin
    • Nilok Productions
Re: Power Connector
« Reply #14 on: March 18, 2005, 11:52:35 am »
I think it's more for cosmetics.  You can either have one of these supplying power to your cabinet, or you can have a power cord hanging out of it from the powerstrip.  Doesnt look as sloppy if you have one of these and you can buy the cables at a dollar store.
quarterback
Re: Power Connector
« Reply #15 on: March 18, 2005, 02:10:33 pm »
The picture and link I posted above does have a rocker switch.
-- Chad Tower
Flinkly
Re: Power Connector
« Reply #16 on: May 24, 2005, 07:17:49 pm »
ok, i'm resurecting this thread to get some input about an entry model i want.  first, i'm looking to add this to the outside of my cab just so that i don't have to have a cord sticking out for power.  second, i'll have power strips on the inside, so do i need fuses or filters?  i'm not looking to save money, just to do this right the first time.
i figure i only need the basic connector like on the first page of schurter power entry stuff, but i really do't know.  i'm also looking to order some buttons, otherwise i'd rob an old power supply.
thanks for the help guys.
http://www.mouser.com/catalog/622/762.pdf
