Main > Main Forum
* SlikStik Lighted Joystick Handles -New Photos- *
SlikStik Christian:
Agm,
Absolutly, you are welcome to come down and pick your order up in person, just email us at info@slikstik.com to setup a time and date.
Tboy,
Yes, they are powered directly off of the I-Pac, nothing else needed. As for shipping them to NY or NJ so that they will have them in time, no problem. If that
Hoopz:
I placed an order tonight for 4 handles. Has anyone ordered recently and can state how long it took to receive their order for these?
Not that I am impatient or anything.... :)
Santoro:
Christian, any chance you will ever come out with these for the Galaga/MsPacman 4-ways?
markrvp:
--- Quote from: Santoro on April 02, 2006, 07:03:38 pm ---Christian, any chance you will ever come out with these for the Galaga/MsPacman 4-ways?
That's a Super base, so the lighted handles for the Happ Super should work perfectly in the reunion stick. It will be taller, though.
MikeQ:
I would stay away from the auto color cycling version of these handles if you plan to use them with an LEDWiz. For some reason (I tried to get support from SlikStik but got no answer) the balltops don't cycle through colors correctly when hooked to an LEDWiz. I suspect it is because the LEDWiz is doing some modulation. The LEDs/circuit used in the balltops don't like the modulation and basically just flicker mostly red all the time. If I knew a little more about the LEDs/Circuit used to cycle the colors I could probably offer a solution. I'll probably gut mine one day to find out what the issue is. I'll post pics/info when I figure it out. It isn't a priority right now though. It will probably just require a diode and capacitor to even out the signal. This might mess up waveforms from the LEDWiz though. I may also just re-engineer them and put an RGB LED in the balltop so I can select my own color scheme from PowerMAME.
