Main > Main Forum
Will this work for Tron?
Pages: << < (3/3)
telengard:
--- Quote from: NoOne=NBA= on February 24, 2005, 07:36:33 pm ---That joystick will NOT be perfect for Tron.
It is an 8-way, and will zig-zag on the lightcycle stage.
If you ARE going to try that type of stick, I'd pick up a used Xenophobe stick.
They are much cheaper, and are the same stick, except that they use a leafswitch setup rather than the microswitches on the Happ.
The push/pull is only used on DOT and Zwackery.
I have a Xenophobe stick and it still zig-zags on the light cycles stage.   :(
I'm going to either have to find an appropriate restrictor or buy a real Tron joystick.
NoOne=NBA=:
I wasn't saying that it would work on Tron.
I was saying that the Xeno sticks are the same stick as the Happ, but use leafswitches, and are alot cheaper.
Doc,
You really should try turning your top restrictor 45 degrees.
They are the same size as the Tron ones, but are just turned differently.
You'll have to cut two corners off to turn it, but it will work.
The top restrictor is the important one.
The lower restrictor is just cheap plastic, and helps guide the actuator.
The top restrictor is the one that takes all the abuse.
daywane:
--- Quote from: telengard on February 25, 2005, 10:40:58 pm ---
MinerAl:
I made a Tron stick out of a Happs Super and a blue trigger handle from an analog Mac stick.
I haven't tried this yet, but wouldn't it be possible to shave the hourglass shaped thinggy (that's the technical term) so that it would hit the corners, but only barely?  Seems like it'd be possible with trial and error to find a happy medium.
Just a thought.  I'll let the board know once I have the free time to try it.
Knievel:
Thanks for all the suggestions guys...Paige/Kremmit steered me the right way.
Did some testing and we're going with 2 of top-fire sticks that Randy sells.
Cheap and effective.
Pages: << < (3/3)
Go to full version
