Poll
What should I do with this cab?
MAME It
1 (3.6%)
Restore it to its former glory
11 (39.3%)
Trade it as to someone for a MAME cab
16 (57.1%)
Total Members Voted: 27
Author Topic: Is Missle Command a good cab for a newbie?  (Read 2169 times)
j123vt_99
  • Last login:August 24, 2006, 09:41:12 am
« on: February 24, 2005, 11:37:33 am »
I have an opportunity to pickup a old missle command. The cab seems to be in decent shape and the game still works... However, I really have no interest in the game itself. I do want to convert it to MAME. AS you know I am a newbie. Should I pick it up and use to experiment with? Pick it up and try and trade it? or just leave it for someone else
« Last Edit: February 24, 2005, 04:00:34 pm by j123vt_99 »
Pictures of my Missile Command  http://www.nimsu.com/mc/mc.html
Witchboard
Re: Is Missle Command a good cab for a newbie?
« Reply #1 on: February 24, 2005, 11:43:28 am »
Depends on how much they are asking.
« Last Edit: February 24, 2005, 11:47:14 am by Witchboard »
j123vt_99
« Reply #2 on: February 24, 2005, 11:46:20 am »
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #3 on: February 24, 2005, 11:51:08 am »
Are you sure that's a Missile Command?  The 4th picture looks like it but the first three are a lot wider and shorter than I remember.
-- Chad Tower
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
« Reply #4 on: February 24, 2005, 11:53:29 am »
That looks in relatively good fettle for its age. MAMEing it and cannibalising parts would be the equivalent of painting a classic car with yellow emulsion.
If you can keep it as is, or sell/swap it, then go for it, but it would be criminal to cannibalise it.
Still, its up to you at the end of the day.
I didn't touch it....honest!
j123vt_99
« Reply #5 on: February 24, 2005, 11:55:35 am »
thanks guys...
paigeoliver
  • Awesome face!
« Reply #6 on: February 24, 2005, 12:04:18 pm »
Missile Command is normally a $400 - $600 game. But my first offer on any game is $100.
Maming that would just be throwing money out the window. Free and sub $50 cabinets are so easy to find it is crazy.
j123vt_99
« Reply #7 on: February 24, 2005, 12:06:06 pm »
ok.. i won't mame it...now will it fit through my apartment door
paigeoliver
  • Awesome face!
« Reply #8 on: February 24, 2005, 12:11:03 pm »
Yes, of course it will, that cabinet is 24.5" wide, your apartment door is probably 36". It will be 30" at a minimum, but the front door is probably 36".
Arcadiac
  • Last login:April 14, 2020, 01:26:31 am
« Reply #9 on: February 24, 2005, 12:14:24 pm »
Before buying, measure all doorways the cab needs to fit through and consider if your are going up or downstairs as turning corners could be a problem requiring the cab to be moved while held upright.
paigeoliver
  • Awesome face!
« Reply #10 on: February 24, 2005, 12:19:28 pm »
I can save you trouble on some measurements though. All color Atari uprights before Gauntlet will fit through all doors. Unless you have some really idiot door. Most classic cabs are 24.5" or less wide, and even the narrowest doors are wider than that.
The really troublesome games are not the classic color cabinets, they are the pre-classic black and white games (tended to be larger) and the post classic deluxe cabinets. Most will STILL fit throught a 30" doorway (which seems to be the smallest common size), if you take the door off the hinges.
j123vt_99
« Reply #11 on: February 24, 2005, 12:19:44 pm »
thanks everyone.. for now it will be going straight into my apartment (1st floor, no turns).. i'm in austin texas. i figure i will get it and see how much of it i can handle...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #12 on: February 24, 2005, 12:32:22 pm »
Don't MAME. Here are the reasons:
1. It is a bonafide CLASSIC.
2. It still WORKS.
NO MORE!!
j123vt_99
« Reply #13 on: February 24, 2005, 01:55:36 pm »
seller told me Exact dimensions: Height: 64.75". Width: 32.00". Depth: 25.25". Weight:
270 lbs
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #14 on: February 24, 2005, 03:06:17 pm »
If you have stairs, you can navigate them easily by strapping it to an appliance dolly.
Lilwolf
« Reply #15 on: February 24, 2005, 03:23:16 pm »
I wouldn't mame a cabinet for more then 100 bucks at this point... But of course I did... but I spend 200 bucks shipping to get one to the top of a mountain in New Mexico... (ie, nothing local).
but after ripping everything out and replacing the CRT it really was a box...
There is one exception to this... I WOULD pay a bit more for really really cool artwork...
But no matter what you do... try and keep the original cp in tact if possible.  So you can turn it back into a missile command whenever you want...
So I would do this..
Its not a jamma cabinet I don't believe... (but find out)
buy an arcadeVGA... monitor is still being used and not modified.
buy a hacked mouse controller from Oscar or a Opti-pac... Now you can use the trackball without change.
Then make it so you can swap the control panel with a standard (and hopefully wood) for all others... So you can swap back/forth with a little effort.
last (duck... swings coming my way)... you might be able (depending on the quality) part out everything you dont' want and make a ton back
trackball... its a 4"  if in great shape you should get 50-75 for it pretty easy.
raised lit up buttons - 20 bucks each (and you get 3 of them... (and for player 1 / 2)
known working board... not sure... check ebay... probably 50+ for it... depends
it might make it worth it..
j123vt_99
« Reply #16 on: February 24, 2005, 03:29:28 pm »
since it is not a jamma, can i use a jpac? and i would only need the opti-pac if i wanted to play trackball games?
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #17 on: February 24, 2005, 03:32:57 pm »
everyone talks about missle command like its this amazing game. you shoot missles at stuff with some atari graphics... its not like its tempest or something..
mame the thing if you want who cares, it has a pretty open area for a CP so that should be easy to fit some controls in with decent space
you could use a Jpac if you wired it to a jamma harness, you might be better off pulling out that monitor and selling it and buying a PC monitor, much easier for a newbie that way. but whatever you wanna do
"Owens is the ringleader in the ass hat circus"  D K
RayB
  • There's my post
    • RayB.com
« Reply #18 on: February 24, 2005, 03:38:21 pm »
AAAAAAHHHHHHHHHHHH!!!!!!!!!!  :o
NO MORE!!
Stingray
« Reply #19 on: February 24, 2005, 03:44:42 pm »
There will be a special jacuzzi suite in hell reserved for you for that post.  >:(
-S
j123vt_99
« Reply #20 on: February 24, 2005, 04:01:11 pm »
made this a poll since a lot of people seem to be divided
walls83
  • beer is good
« Reply #21 on: February 24, 2005, 04:06:10 pm »
Man I love missle command.  But I wouldnt buy it if you want a mame cab.  Just find a different non working cab and do that.
j123vt_99
« Reply #22 on: February 24, 2005, 04:10:17 pm »
« Last Edit: February 24, 2005, 04:12:41 pm by j123vt_99 »
Witchboard
« Reply #23 on: February 24, 2005, 04:20:52 pm »
If you have no interest in the game itself, don't bother trying to restore it.  Even if you do, you won't get the warm fuzzy feeling inside.  If you do buy it for a good price, your best bet would be to trade it to somebody for a generic cab plus cash.
j123vt_99
« Reply #24 on: February 24, 2005, 06:18:57 pm »
also .. recommendations on getting this beast into my truck.. borrowing my friend's truck... can i use a ramp and dolly? any suggestions? do places rent these?
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #25 on: February 24, 2005, 06:30:38 pm »
just put the cabs back up to the truck bed, lift/tip it into the truck so it lays on the back. its ok to leave it on its back
j123vt_99
« Reply #26 on: February 24, 2005, 06:33:03 pm »
anything else i should bring along besides a tarp and bungee cords?
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #27 on: February 24, 2005, 06:44:47 pm »
Straps...
To keep it from sliding around the back of the truck...
Blankets/padding...
To keep iot padded against the bottom & whatever you strap it against.
You can leave it on it's back, or once you've got it up there, you can stand it up & strap it to the front.
Either way, make sure all loose parts are secured. (Plexi, control panel, etc...)
Look inside the cabinet & make sure nothing is loose in there... a couple of rough starts & stops can throw loose objects around & destroy the game boards & or monitor chasis...
Have fun!
- Thomas
I'm not a freak!...
Oh wait...
Yes I am...
RayB
  • There's my post
    • RayB.com
« Reply #28 on: February 24, 2005, 07:26:00 pm »
He just said it, but to emphasize: Look for bolts, nuts and quarters at the bottom and remove them.
Next, when you get it home, open it up and re-check again for anything that has come loose BEFORE you power up.
NO MORE!!
j123vt_99
« Reply #29 on: February 24, 2005, 07:36:24 pm »
forunately it is a short ride (can;t be more than 10 miles)...still need to figure out how to load it... not 100% sure i can get a buddy to come along
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #30 on: February 24, 2005, 08:59:55 pm »
I'd say, preservation aside, a Missile Command would be a poor choice for a MAME(tm) cab....
The standard CPO is pretty limited, and it will be a pain to have a blank one fashioned or fit a new one in.
The monitor is it isn't really suitable for anything besides old Atari games.
The wiring in it predates JAMMA by like 1000 years.
No place for a custom marquee.
And don't listen to Sephiroth. He's a cool guy, but too damn young to respect what a frigging cool game Missile Command was back in the day.  ;D
j123vt_99
« Reply #31 on: February 24, 2005, 09:17:10 pm »
Everyone here has convienced me not to make it a MAME cab
dabone
  • Last login:October 31, 2023, 12:03:37 pm
  • Time to work...
« Reply #32 on: February 24, 2005, 10:12:47 pm »
Post it for sale on the rgvac news group.
It looks like all it needs is some tlc and cleaning to make it a nice collectors piece.
It will find some love there.
(I've had to pay 20 bucks a piece for the cone buttons on the control panel alone.)
And you'll get enough to start you on your mame cab.
(Ipac, avga, etc.)
Later,
dabone
paigeoliver
  • Awesome face!
« Reply #33 on: February 25, 2005, 08:29:30 am »
270 lbs
He has his width and depth mixed up, but otherwise those are correct.
j123vt_99
« Reply #34 on: February 25, 2005, 08:41:14 am »
270 lbs
i was hoping that was true
Wade
  • Last login:November 29, 2023, 08:30:51 pm
  • 80's Child
    • Wade's Gameroom
« Reply #35 on: February 25, 2005, 12:12:39 pm »
That's a decent game, get it for a good price and sell it for more.  I'd take a MC if I could find one locally.
Then take the money you made and build a Mame cabinet.  There are lots of great Mame candidates (broken games, gutted cabs, etc.) for very little money.  It's a shame to do it to a working classic like that.
Wade
j123vt_99
« Reply #36 on: February 26, 2005, 03:26:35 pm »
picked her up and she is a beauty.. works great.... even had the original instructions taped in the inside
the trackball is huge at 3 in... could use a little bit of lube/wd40 ...
still has the state inspection stickers for 82-84.. artwork is pretty solid... i actually think it looks good with a little wear.. if it was too perfect, might look like a reproduction
dmsuchy
  • Last login:December 19, 2009, 09:00:08 pm
  • I kill communist llamas for fun.
« Reply #37 on: February 26, 2005, 05:28:43 pm »
How much did she cost ya?
j123vt_99
« Reply #38 on: February 26, 2005, 05:32:19 pm »
 :-X.. i think well.... and it  isn't about the money, is it?
dmsuchy
« Reply #39 on: February 26, 2005, 05:47:17 pm »
No, it is all about da money and the beeeatches, if current rap videos are correct.
