Main > Everything Else
What do you recommend to test your system's memory?
Sephroth57:
so, you ended up using memtest86 then?
DrewKaree:
My bad! Yes, I did end up using Memtest86....I don't know how long the tests go, but I got an error message pile of info ~33 minutes into the test.
FWIW, none of these kinds of tests seem to be particularly fast, nor would I expect/want them to be, but I don't know just how long memtest86 actually takes.
