Main > Main Forum
Why JAMMA?
Pages: << < (8/10) > >>
paigeoliver:
--- Quote from: RayB on February 24, 2005, 05:27:48 pm ---
--- Quote from: SirPoonga on February 24, 2005, 04:58:41 pm ---Wouldn't a multijamma unit solve this problem?
Too expensive, and the arcade power supply would still be sending power when the multi-unit was switched to the J-PAC.
Multi-Jamma powers all boards at the same time, so yes it would solve that problem.
SirPoonga:
I thought so, when I emailed the owner of multijamma years ago he said the jpac was tested and works well with it.
SirPoonga:
--- Quote from: RayB on February 24, 2005, 10:17:31 am ---See I keep reading you need to remove (or not power) the arcade switching power supply, because A. You don't want power going to the JPAC, and B. The PC has its own power supply.
Talk to Andy at ultimarc.com.  Does he use the power pins for something?  If not it won't hurt because the power goes no where.
krick:
The power pins on the J-PAC aren't connected to anything.
Pics from my site...
SirPoonga:
I woinder if there is something Andy could do with the jpac then to put load on those pins, just in case.
Go to full version
