Main > Everything Else
Any beer homebrewers here?
Pages: << < (2/3) > >>
Kremmit:
I used to brew.  I no longer do.  Sometimes it tasted like poo.  Good luck to you!
No, really, here's a bunch of tips, in no particular order-
 It doesn't have to be difficult or expensive.  The more you read, the more you'll start to think you have to buy all sorts of equipment, and boil 3 different types of grain and change the temperature every 20 minutes.  That's all well and good after you've tried the easy stuff, but by all means, try the easy stuff first.
My advice is, don't buy a bunch of stuff for the first time out.  You want to see if you like it before you go nuts.  We did our first several batches in a scavenged 5 gal kettle on a regular kitchen stove.  We fermented in a 5 gal. plastic bucket, and in an empty water cooler bottle.  If you can find a local brew supply store, that's better than buying from a catalog/website, until you're confident that you know what you're doing.  The guy at the store can help with a lot of stuff.  If you do find a store, take some empties with you when you buy your bottle capper, try out the different models, have the guy at the store teach you how to use it, and how to spot a cap that doesn't seal.  A cap that doesn't seal is a bottle down the drain.  You need about 40-50 bottles for a 5 gallon batch, and buy extra caps, because you will ruin some.  Buy a bottling wand, and a couple of lengths of clear tubing.  Buy the sterilizing agent, don't try to use bleach, the taste will get in the beer.  Take the sterilizing stuff from the books seriously.  When you siphon, always draw from the top of the vat, never the bottom, as that's where all the sediment is.  When you get to the bottom, it won't kill you to leave that last little bit down there, instead of running the siphon too far down and pulling up a bunch of mung.
Brew from extract at first.  Don't kill yourself trying to go from grain, it adds all sorts of complexities to the process.  Get a hop bag- it's a sack made from cheesecloth, more or less.  Put all the hops inside it, and when you're done, you just pull it out and toss it- saves a ton of time straining the stuff.   Still, have a really big strainer (the wire mesh kind, not the pasta collander- holes are too big) to run the stuff through before you put it in the fermentation vessel.  Get a candy thermometer, and don't put the yeast in untill it cools down enough, or you'll just kill the yeast.  Keep a CLEAN lid on as much as possible after the boil is over.
Do labels, people think it's cool:
DrewKaree:
Someone here does it, I know for certain.  I was checking out their cab site, and their home brew site was bigger than their cab pages!
I have 2 buddies who do, and the one I pointed to this thread told me, firstly, that the guy whose beer tasted like Clorox needed to practice better sanitation processes.  The reason it would taste (he said it probably SMELLED like Clorox, rather than tasted like it) like that is not rinsing well enough, or not allowing the stuff to dry well enough - other than those two things, you just used too much bleach.
I know what you mean about too much information to absorb....I was contemplating this, and still may, but Zakk's right, making wine is WAY easier, and the screwed up batches are still drinkable!
If you find some good sites, post 'em back here, I'm betting you aren't the last person with these concerns and questions!
DYNAGOD:
yea,im lucky enough to have a local hobby shop that sells home brew supplies, i plan on going there this weekend and grilling them for info. they are also affiliated with the local brewing club,so that could prove usefull.
I luckily like darker ales,porters,stouts.. so that cuts down considerably on the work involved from what ive read. Ales from what i understand take considerably longer.
heres some links ive found in my hunt.
http://www.howtobrew.com/intro.html
http://brewery.mvlan.net/folder/011/Homebreweries%20Directory/
http://www.brewboard.com/
http://www.clanward.com/brewery_files/Homebrew%20Glossary/homebrewersGlossary.htm
_Iz-:
My friends and I made some when we were in college - we wern't quite patient enough and we would drink it slightly earlier than we should. The head on it always tasted like gravol...   :-\
SeaMonkey:
Start with a pre-packaged kit, like so:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=38172&item=4358601082&rd=1&tc=photo
then buy custom equipment as you find brews you want to make that you don't have the equipment for. It is a cheap way to get in.
I also suggest getting a good book on brewing mead.
Go to full version
